Results 1 to 14 of 14
Thread: Turbos
    Oct 2002
    1986 Honda Accord
    Gainesville, Fl
    Turbos
    If you are putting a turbo onto an engine would you want to use the deepest dish style pistons? Or would you use a piston that is closer to a flat top?
    hondaman87's Avatar
    88 honda accord DXE-i H/b 91honda accord wagon, 01 gsxr 600
    medford, mass
    as far as I know u have to put the deep dish to lower your compression
    10/Honda/Ridgeline
    NJ
    lower ur compression with those special cleaves on the piston head. Talk to Justin (88turboAccord) he would help u a lot cause he had the working turbo on a A20.
    sorry man, i dont know what the fuck i was smoking.
    2000 Audi S4 Twin Turbo/ 2007 Honda Fit Sport/ 2010 Ford Flex Limited
    Temecula, CA
    My Name is Justin... Anyways, you want the dished pistons.. Reason being, that is how you lower your Compression ratio..
    1-11-2014 Dyno Day
    587 - AWHP
    454.6 -TQ
    http://youtu.be/TqCtTbjQqFg
    www.tvme.info
    88 Lxi/ 5spd
    Tennessee
    Hey Justin ,,,(HaHa I know his name...j/k).....could you get away with using a thicker head gasket or would that spell just more trouble?
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    Temecula, CA
    Well since I went through 4 head gaskets in 1 year, I do not suggest it. Eventually I will replace the stock head gasket with a copper one.. The stock stuff doesn;t like the 20 plus psi of boost all to well.. I do not mind changing them on my car, pretty much everything is simple to me now.
    1-11-2014 Dyno Day
    587 - AWHP
    454.6 -TQ
    www.tvme.info
    88 Lxi/ 5spd
    Tennessee
    Hey I didn't catch what turbo you exactly used and where you got it. I was leaning to a T-25 Garret for quick spool times or is this turbo to small for our engine size. Did your tubo have an internal wastegate? I was hoping the T-25 does and i'm pretty sure it does since it was factory equipped on alot of models.
    Temecula, CA
    I am running a t-3 super 60 turbocharger... The biggest t-3 turbo made. I don't use an internal wastegate.. I use a turbonetics deltagate markII.
    1-11-2014 Dyno Day
    587 - AWHP
    454.6 -TQ
    www.tvme.info
    88 Lxi/ 5spd
    Tennessee
    Damn man but your talking alot of $$$. I was wanting a custom setup for around 4 to 5 hundred dollars (minus the exhaust manifold). T-25 are pretty plentiful around here. I'm not familiar with the type your using......who makes it? I know the T-25 garret can't handle more than 15psi .....but at first I was wanting to get about 5-6psi to save on costs (no intercooler). So cheapest setup would be a T-25, BOV, Tubing, Custom Exhaust Manifold $$$, high flow fuel pump, custom oil and cooling lines,......anything else major I'm missing .......I might spring for a boost gauge too.
    Temecula, CA
    You need:
    Custom Manifold (Exhuast)
    Custom Downpipe made
    Blow Off valve
    Ignition.. MSD BTM (Boost timing master) I would suggest this)
    Inline Fuel Pump
    Turbo with intergrated wastegate
    Boost gauge
    a "t" for the oil to the turbo (off of the oil filer housing)
    an oil return set-up (to the oil pan, requires welding)
    Vortech FMU 12:1
    Piping
    Clamps and silicone slips
    Misc. clamps, hoses, stuff.
    I would also get a FPR along with a fuel pressure gauge
    But you are still looking for around $1200-$1500 if you play your cards right, buy a lot off of ebay.
    1-11-2014 Dyno Day
    587 - AWHP
    454.6 -TQ
    www.tvme.info
    S.Glastonbury, CT
    I dont think your gonna pull that off for 4-500, a stock fuel pump is over $150. Im not saying it cant be done cheap but you still have some core requrements to meet before you can run the turbo. I would check out www.homemadeturbo.com if you didnt already. he does it as cheap as possible but he runs higher levels of boost. I am gonna build a turbo someday but only the correct way because of the high maitnance and i want it to be reliable. I think your gonna have more problems than you want such as weak clutch etc. Its gonna be one thing after another and if its your daily driver i would reconsider unless you have another car.
    88 Lxi/ 5spd
    Tennessee
    I do have another car. I have an act clutch. Its not my daily driver. I can pratically get the turbo for about 50 bucks. Fuel pump 150 bucks. BOV for around 150 if I can pull that off> That leaves about 200 for the misc stuff. I already have the FPR and the gauges. Like I said this is cost without the manifold and pipes. I don't know maybe I'm crazy and Its going to cost me an arm and a leg
    88 Lxi/ 5spd
    Tennessee
    Ok can you answer this one question for me. How do you fool the map sensor into seeing vacuum when the manifold pressure is going to be positive. Will this screw the computer up bad and if so how is it fixed?
    88 Lxi/ 5spd
    Tennessee
    Also explain that 12:1 fmu......that seems awful high even on an inline pump. Your talking 100psi of fuel pressure on modest boost (5-6psi) .....want that crap out the fuel system?
  1. have a ? on turbos
    By hblxi87 in forum Forced Induction
    Last Post: 11-20-2003, 02:07 PM
  2. have a ? on turbos
    By hblxi87 in forum Performance
  3. Turbos
    By Festo in forum Forced Induction
    Last Post: 11-14-2003, 08:00 PM
  4. Turbos
    By Wild LX-i in forum Forced Induction
    Last Post: 09-23-2003, 09:27 PM
  5. Turbos
    By Wild LX-i in forum Performance
