Page 1 of 3 123 LastLast
Results 1 to 25 of 62
Thread: MoNstER A20 All MoTOR !!
    LX User 247shuer247's Avatar
    Feb 2011
    1986 accord lx-i
    Cool MoNstER A20 All MoTOR !!
    Ok guys So i have been Working non stop on my hatchie and have become so inspired with everyones mods and unique ideas on here so first of all thank you to everyone for the inspiration and thank you in advance to whoever posts on this thread . sorry in advance if i babble
    so for starters i have a 1986 accord hatchback.
    HERES WHAT I HAVE DONE TO DATE ....
    Fixed all the mechanical parts the car is running great nice and strong
    i replaced the entire cooling system clutch changed belts everything that would wear with age. my ac and power steering were already failing so i removed those and also the cruise control which freed up a bit of my engine bay
    my next project was the body work getting rid of all of the dings and scratches not to many was able to get the body looking nice with very little bondo
    looking on prelude power i found that alot of the 2nd gen guys were modifying there bumber to fit the 3rd gen. and i remeber that we could fit 2nd gen prelude bumpers with some modsso i took on the task of modifying the front bumber to fit the 3rd gen as far as i know mine is the only one with a 3rd gen bumper
    pics will be up soon
    as of now the car has been primered I am holding off on the paint job until i get some work done on my engine heres where you guys come in i need your help.
    I plan on rebuilding the engine not to many problems now just want a reliable engine... once the engine is out i will spray the engine bay and finish the paint..
    heres my plans for the engine this is not set in stone and any advice would be appreciated
    *FULL ENGINE REBUILD
    port and polish the whole thing
    *B16 INTAKE MANIFOLD AND THROTTLE BODY thinking after market on this maybe skunk2 ? would it make a difference?
    * HEADERS im thinking obx because i have heard bad things about pacesetter. and ss and dc headers are really hard to find .
    *Short Ram Intake weapon R heard alot of good things, can anyone say different maybe k&n
    *Upraged ignition ??? i have no idea about this one
    *4TH GEN INJECTORS most likely oem
    *ALUMINUM FLYWHEEL again no idea any info would be appreciated
    *NGK SPARK PLUGS AND WIRES pretty much
    *BIGGER PISTONS ... would this make a difference? if so what size is good?
    *Pelude A2k5 tranny
    * Convert to obd-1
    *Ehaust not to sure here ive seen that obx has an exhaust kit
    but im a little skeptical and have no idea for a muffler
    *Stage 2 cams and Gears thinkin colt where can i get them?
    *Upgraded rods ? No idea where to start ....
    like i said This is not set in stone open to any advice whether its negative or positive im just trying to get it right the first time ....
    Mar 2010
    88 lxi
    lawrenceville, GA
    Re: MoNstER A20 All MoTOR !!
    obx utilizes the ss design. lost posted about that somewhere sometime. if your going all motor and obd1 you should look into either fabricating some itbs or buying a set. youll be able to tune easily so why not go all out? how much power are you looking to put out?
    88 lxi:
    Feb 2011
    1986 accord lx-i
    I was thinking that but i have no idea how much that would cost or if they would need to be custom made
    im shooting for something like 200 but i would be happy as fuck with like 160
    i dont think thats to farfetched
    yeah i do remeber pete posting that
    Dec 2003
    Millington, TN
    I have a brand spanking new DC sport header, always entertaining offers.
    Phil
    I have a skunk 2 manifold already drilled to fit
    Feb 2011
    1986 accord lx-i
    with or without the throttle body ?
    Feb 2011
    1986 accord lx-i
    Quote Originally Posted by nswst8 View Post
    really brand new ??
    umm idk how much would it be just to ship to california ?
    Quote Originally Posted by 247shuer247 View Post
    i can throw in a GSR throttle body if i can find it
    Mar 2010
    88 lxi
    lawrenceville, GA
    160 is easily doable without bottom end work. Build.the head,get a good cam,headers and an intake manifold and im sure you could get close to that.
    88 lxi:
    Feb 2011
    1986 accord lx-i
    How much do you want for it bro ??
    ''YOU MAY LOSE MONEY CHASING WOMEN BUT You will no doubt end up broke as a mothafucka chasing cars''
    Feb 2011
    1986 accord lx-i
    Quote Originally Posted by 88lxi-shortram View Post
    160 is easily doable without bottom end work. Build.the head,get a good cam,headers and an tintake manifold and im sure you could get close to that.
    Just curious what can be done to the bottom end ??
    And how much horsepower could be gained by doing that ?
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    bottom end. LS rods with some high comp pistons.. 12:1 if you're going all motor
    something like THIS
    -Gio
    My E85 Turbo Build
    5280FEST
    following this thread,
    your only real choice on a header thats stainless is the OBX now or that DC if you can get it. I got one of the last S&S ones, the OBX is all right but may need some of the welds redone from what I've seen.
    Feb 2011
    1986 accord lx-i
    something like THIS
    Does that one fit the a20 and yes I plan on staying all motor
    Trying to bring n/a back
    same here all N/A old school
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Yes LS rods and pistons will fit. You'll have bore the block to 83mm to get them to fit and get custom pistons made to match(thank messy for that info). Also your going n/a you may want to look in to ITB's you'll make power with them then a b16 intake manny. However you would have make your own ITB's. You also better get ready to run the bottle. A 75 shot should do the trick. A 5 angle valve job. Maybe even bigger valves. All this would be a nice start and get too your 200hp mark and maybe more.
    A Mile High.
    Don't have to get customs pistons.. Just get some off the shelf pistons with the bore you want. There's plenty of pistons out there in 83mm and 84mm that you can buy right off the shelf. Just make sure rods are LS. I believe all aftermarket pistons; itr, ctr, gsr, etc; will all fit aftermarket LS rods... This info has been around for YEARS. It's just recently that people have started using B series internals more often.. Check out the FAQ section...
    In theory, you can use b16/b18 ITBs. I think 200 is pretty achievable without spray... Read Rich's(rjudgey) threads/post on head work, he's a god when it comes to that! I think it's all gonna come down to headwork to reach that power.. BIG valves, big cam, nice porting, etc...
    -Gio
    My E85 Turbo Build
    5280FEST
    LX User knifemind's Avatar
    Mar 2008
    88 dx & 85 Lude
    Montana
    http://www.extrudabody.com/servlet/t...0-Motor/Detail
    Feb 2012
    89/accord/lxi
    12:1 comp pisrons at a 83mm isn't some the u can just get "off the shelf". Most ls pistons are gonna be 10:1 with a 81mm or 84mm bore. The size needed is 82:7xmm.... so I would have to ask why would you run 84mm over and weaken your sleeves more then needed.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Except we don't have sleeved blocks.
    Service limit for these blocks according to the factory manual I just checked is 30 over, which would be close to a, 83mm piston. That's as large as I would go.
    Diamond can make pistons to order. They have a file on hand for our engine, too. Give them a call.
    Feb 2011
    1986 accord lx-i
    So basically 12.1 83 mm with ls rods and the head bored to the same is crucial
    Is diamond pricey with the pistons??
    And lost I agree n/a all the way
    And as for itb I'm gonna have to do some serious research on them first lol
    Feb 2011
    1986 accord lx-i
    It's funny because I just recently found his thread and he is god at this lol
    Feb 2011
    1986 accord lx-i
    Me is confused what do you mean by run the bottle what 75 shot ?
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Nice can't wait for the outcome of this engine. im doing something similar but leaving room for more power. im trying to go for 140-160hp n/a for now, hope all goes well for your build. i suggest going obd1 for tuning.
    Quote Originally Posted by ShyBoyCA6 View Post
    I think he's going carb
  1. Simple exhaust job turned monster!! lol
    By Kemikals in forum Classic Honda Community Chat
    Last Post: 09-05-2007, 04:54 PM
  2. Purple Monster: Revisited
    By BDaccordguy in forum Classic Honda Pics & Videos
    Last Post: 02-28-2007, 11:26 AM
  3. Monster Sound System
    By 3rdGAccordGuy247 in forum Trading Post
    Last Post: 04-01-2004, 02:37 PM
  4. New Pics of the Purple Monster **NOT 56K FRIENDLY**
    Last Post: 03-25-2004, 09:05 PM
  5. top end monster?
    By Morpheus in forum Performance
    Last Post: 05-20-2003, 09:17 AM
