Results 1 to 7 of 7
Thread: Weird Idling issue
    DX User Gt-r's Avatar
    Aug 2012
    1989 Honda Accord Lxi-I
    Weird Idling issue
    I have a 89 Honda Accord that has been having wierd idle issues. Somedays it will idle normally at around 1000-1500 rpms on a fresh of the day start up. And the rest of the day it will idle normally. But like today it went straight to 3000 rpms and didn't lower down until bout 30-40 minutes later. And it would rev idle itself upto around 3500 rpms at will.
    But the only time it didn't do this funky idle is when my heater hose was bout to rupture. It actually idled itself normally.
    Jul 2012
    Re: Weird Idling issue
    Quote Originally Posted by Gt-r View Post
    Your distributor is probably loose
    Aug 2012
    We had checked the distributor and it's snug like it should be.
    .:Honda Vehicles:.
    None
    .:Limbo.
    The Blue Bitch(89 Honda Accord)
    Crushed:
    1989 Honda Accord Lx-I 4-Speed A/T
    1988 Honda Accord Hatch Lx-i 5spd M/T
    LXi User Buzo's Avatar
    Dec 2010
    North of Mexico
    Something is opening the throttle body for you and causing the high revs.
    Stuff connected to the throttle body's shaft:
    1) The choke assembly. Jammed mechanism.
    2) The Idle boost solenoid. Vacuum leak in the hose. (passengers side vacuum actuator).
    3) AC boost solenoid if equipped. (drivers side vacuum actuator).
    The service manual is somewhere here in the forum.
    The only way an engine can accelerate, is letting air entering through the carburetor's throttle body, so the air flow can suck the required fuel and the combustion can be maintained.
    If you apply fuel only, the engine will die. If you apply advance only, the engine will die, if you let air entering through any place other than the throttle, the engine will die.
    Carb or FI?
    Aug 2012
    Carbed
    .:Honda Vehicles:.
    None
    .:Limbo.
    Crushed:
    DX User H86accord's Avatar
    Feb 2012
    1986 honda accord
    yakima wa
    i think its a vacuum leak. does it die when its warm and the choke is fully open after you step on the gas? if it does it might be this vacuum line.
    http://www.pauldesign.ru/honda/shopmanual/62se300.pdf
    go to page 9-3 its a hose that goes to manifold to manifold it looks like a n. check if is cracked then replace if needed.
    hope that helps
    1986 accord;
    Pace setter header 2.5 inch exhaust , armrest and cupholders,
    1200w 15in sub, painted hood.
  1. Idling issue, please help!!!!!
    By logan9691 in forum Carburetor Tech
    Last Post: 03-06-2013, 11:06 PM
  2. idling and engine issue
    By panthere0rose in forum 3geez Accords
    Last Post: 06-08-2012, 08:27 AM
  3. idling issue, hot engine (Weber)
    By TotaledTL in forum Carburetor Tech
    Last Post: 01-02-2012, 06:27 PM
  4. 89 SE-i weird idling issue
    By silverjdmcoupe in forum EFI Tech
    Last Post: 12-19-2009, 08:08 AM
  5. Idling Issue....
    By New3rdGenOwner in forum EFI Tech
    Last Post: 04-05-2008, 10:12 AM
