I have a 198 Honda accord LX-i
I have replaced the radiator fan assembly and motor, as well as the cooling fan switch, I also replaced the thermostat. The rad fan WILL NOT COME ON.
I have replaced the fuse for the rad cooling fan still no luck however when I switched the fuse it did come on shortly then turned off again...
does the accord have a second TW/ECT switch near the therm housing, should that be replaced, also there are two switch like items in the thermostat housing one is the TW/ECT the first one and then right next to it is another sensor looking switch, what's that i tried to look on the manual but it only list the TW/ECT switch...
