Results 1 to 5 of 5
Thread: Brakes
    Oct 2002
    2002 SE-R Spec V, 1989 Accord LXi Hatchback
    Philly. PA
    Brakes
    Looking at getting a set of cross drilled rotors for the 89 LXi hatchback. I know powerstop makes them, not sure if anyone else does.
    Any suggestions on brands of rotors and pads? Any input is appreciated.
    -Joe-
    '02 SE-R Spec V
    '89 Accord LXi
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: Brakes
    -Joe-
    www.raceconcepts.com
    slotted and dimpled brembos, the real thing. I got mine for only $100 for the pair, not sure what their selling for now. I ran them with EBC pads. They took my kind of testing and didn't whimp out. 25-30 miles 100% as quick as I could go along back road foothill roads. I was either braking, cornering or into the throttle 100%, for the distance. No fade, easy to modulate, I highly recommend them. The catch is, if you really take advantage of what they can do, allot,.......they do make a fare amount of dust. In spite of that, you can bet my next car will have them both the brembo's and EBC pads.
    Now I d
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    how much for "everything" you would need? (i would have to get bigger wheels but i am not counting that)
    and would 14s work? if so i can just snag some at the junkyard!
    Oct 2002
    Philly. PA
    Re: Re: Brakes
    Once again Jim, that's exactly the info I wanted. Thanks again!
    -Joe-
    '02 SE-R Spec V
    '89 Accord LXi
    Central California
    When I did that I stayed with the stock sized rotors, I did not upgrade to the larger 88-89lxi rotor's. But if you want to do that, they have that size of rotor as well.
    And yes 14's would work, that's what the factor did.
    Now I d
  1. Big Brakes and Addco rear sway bar on sei brakes
    By EricW in forum Classic Honda Pics & Videos
    Last Post: 10-01-2007, 01:13 PM
  2. got the brakes in
    By alboy86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-26-2007, 09:46 AM
  3. no brakes
    By 89HondaLxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-03-2005, 09:50 PM
  4. Switching carb brakes to EFi brakes...
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-21-2005, 04:09 PM
  5. brakes.... my kingdom for new brakes
    By 89accord_lxi_coupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-02-2003, 04:11 AM
