K well idk what the hell is strong with me I usually figure this crap out. I know how the system operates . I'm obd1 an im using the original harness modded with boomslang jumper Ecu harness. Are accords use a stand alone fan controller to run the fans. I don't see any fan control on the Ecu Pinout . I'm trying to wire up the fan switch on t-stat which would be fairly easy.
How did you obd1 guys wire up the fan switch on a b series I try tracing the wires back to the relay box an was just going to run wires to the switch . But the Ecu is not in control. The obd1 fan control is on the Ecu an that is (a12) an it is blank. So I'm like wtf.
I'm just making it Harder then it seems. Help a brother out.
