Lol..
The black yellow is infact the positive (15), assuming is not good in this business!
Blue is the ignition signal, dont connect anything there...
OK, the big ass wire going from the middle of the coil to the distributor is the one sending the spark to the spark plugs. Leave it alone for now.
If your wipers start moving, that means the wiper switch in your steering column is activated. Turn it off.
Feed the #15 (BLACK & YELLOW wire) and do the following checks:
Your red dash indicators should lit.
You should hear the fuel pump close to the rear left wheel clicking.
If everything is ok, the crank the starter and start that engine.
I'll be here if you need some more advice.
Or you can mail me is anything is not working as intended.
[email protected].
Good luck.
