I recently replaced the altenator on my daughter's '88 Accord. I noticed that there was a leak coming from the passenger's front side of the engine (it's near the cylinder closest to the distributor). I'd read that the distr O-ring could cause this and changed it out. After degreasing the engine and running it around town for a few hours, the leak is still there!!! My first thought was that the oil is coming from the valve cover because the oil collects around the "timing light hole" and runs down to the front motor mount, the oil pan and eventually the exhaust but, there is little to no oil on the head itself!!
1. Can you guys think of anything else that would cause this leak other than the VC gasket??
2. Can the lack of a "timing hole" plug let oil leak out??
Thank you for your time
