Results 1 to 16 of 16
Thread: Key Replacement
    Sep 2012
    1987 Accord Lx
    Key Replacement
    Does anybody know a good site for key replacements?
    Re: Key Replacement
    If you have an existing key, then Wal-Mart or any hardware store. If you don't, then you need a locksmith. If you have the key code, the dealer should be able to punch a new one for you from that alone.
    Sep 2012
    1987 Accord Lx
    Re: Key Replacement
    Where can I get the key code from?
    Nov 2000
    Re: Key Replacement
    ^I did that once after buying a used car that came with no original keys. You can contact Honda US and prove you are the owner of the vehicle and you can get the key code based upon the VIN. You might be stuck going to a Honda dealer and paying $10-20 for an official key, but I found that having a clean, first generation key can make all the difference. If you go this route, store the one you get and only use copies made directly from it.
    Sep 2012
    1987 Accord Lx
    Re: Key Replacement
    Thanks will look into, I didn't mention the fact that the car did not come with the keys (didn't want to be seen as a theft) So most defiantly will go that route. thanks.
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: Key Replacement
    Quote Originally Posted by DBMaster View Post
    I got my OEM keys from my honda dealer for 6 bucks a piece but they said my car was to old for them to cut keys
    LX User 247shuer247's Avatar
    Feb 2011
    1986 accord lx-i
    Re: Key Replacement
    Quote Originally Posted by Metal_GearRex94 View Post
    theif !!!! lol
    jk shit if you have no key just buy some jingle keys and unlock any honda lol
    ''YOU MAY LOSE MONEY CHASING WOMEN BUT You will no doubt end up broke as a mothafucka chasing cars''
    Re: Key Replacement
    I got OEM keys cut from the Honda dealership with my registration for $4.99 each. Do not get hardware store keys...they are generally low-quality and might break in a lock or the ignition.
    Re: Key Replacement
    The code is stamped into the metal of the original key. It's a good idea to make a note of it when you first buy a car, in case you end up needing it later.
    Re: Key Replacement
    sometimes you can luck up at the junk yard and the keys are left in the ign or inside somewhere, then you could snag the whole lock and key.
    The keys to the 86 DX I had would fit my 86 LX doors but not the ignition, yet the same key that belongs to the LX fit both
    The 87 Lxi keys don't work though
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Re: Key Replacement
    DBMaster x2 here:
    I got an OEM key cut for my civic (paid 7-8 bucks or so); you only need your car registration or tag w/you and they take the VIN to make the key.
    Because that key worked perfect, I made hardware store copies from it and I use those instead of the OEM which I keep as a master key from which to make copies from.
    LX User HON-DUH's Avatar
    Oct 2010
    Re: Key Replacement
    Wait, so if I just go to my local Honda dealership with my registration and my blank Honda keys, they'll do em for $4.99 each?
    Because when I called them like 3 months ago, all I asked was if they made copies from a blank I had and they wanted to charge me $10+
    Thanks
    Apr 2008
    Atlanta, GA
    Re: Key Replacement
    Quote Originally Posted by HON-DUH View Post
    Thanks
    They provide the blanks, but the price is pretty much what the dealer wants to charge (I was charged 7.99 plus tax). Ask in another dealership if there is another in the area; it is worth having a good master key from which to make copies to use.
    Re: Key Replacement
    A lot of times, the dealer will kick you down a 10% discount or so if you just ask. The markup is so high, apparently, that they can knock off a few percent for anyone and not feel it.
    Re: Key Replacement
    i only use my key for the ignition and trunk. i have an alarm with keyless entry. I thought all the original honda keys were sold. maybe they made a new batch.
    Sep 2012
    1987 Accord Lx
    Re: Key Replacement
    Another question. I took Of the ignition switch, because it was already out of place, some one tried to break into it car,while the last owner had it, anyways. I took the whole ignition part off, and know I need an Ignition switch with the key, does any one know if I can use the numbers on the part to get an oem part and key, or are those irrelevant numbers?
  1. Oil Pan Replacement Help
    By Jonessoda27 in forum 3geez Accords
    Last Post: 07-20-2011, 08:06 PM
  2. ecu replacement ?
    By modu03 in forum EFI Tech
    Last Post: 03-03-2006, 03:12 PM
  3. egr replacement
    By Slipknotcraig133 in forum 3geez Accords
    Last Post: 01-14-2005, 04:30 AM
  4. Tie Rod End Replacement
    By X-Lr8 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-23-2003, 07:10 AM
  5. replacement
    By ohmydork in forum 3geez Accords
    Last Post: 10-07-2003, 04:54 PM
