Results 1 to 12 of 12
Thread: Just cleaned out the rust in my gas tank, oops!
    DX User stormsurfin's Avatar
    Jul 2012
    1987 Honda Accord LXi
    Lakewood, CO
    Okay all you technical 3geezers, I managed to inefficiently clean out the rust in my gas tank (compliments of a rusty fuel filler neck).
    Upon putting it back together I created a leak.
    The fitting toward the front of the car (by the gas tank) did not come loose for me to be able to get the tank fully free from the car. Unfortunately, this fitting now leaks (all over my condo's parking lot too) and doesn't want to budge. WTF should I do?
    Re: Just cleaned out the rust in my gas tank, oops!
    Quote Originally Posted by stormsurfin View Post
    which fitting are we talking about the actual tank or something attached to the tank, the tanks don't have a bottom outlet so how is gas getting out?
    Jul 2012
    Lakewood, CO
    8 17700-SE3-A01 PIPE, FUEL FEED
    9 17706-692-003 CLAMP, FUEL PIPE
    10 17710-SE0-931 GROMMET, FUEL PIPE
    11 17712-SA0-000 GROMMET, FUEL PIPE
    12 17712-SE0-A00 CLIP ASSY., FUEL PIPE
    13 17712-SE0-G01 CLIP ASSY., FUEL PIPE
    14 17713-SA5-003 CLAMP, FUEL VENT PIPE (BLACK)
    15 17713-SE0-003 CLAMP, FUEL PIPE
    16 17714-SE0-A00 BRACKET, PIPE CLIP
    18 17715-SE0-000 PROTECTOR, FUEL PIPE
    21 17720-SE3-010 PIPE, VENT
    This is the line to the EFI, which has a hose connection (left side of diagram), my problem is with the fitting (uses 14mm I believe) for the return. its underneath 18 in the top picture
    Jul 2012
    Lakewood, CO
    how did you manage to damage that,was it corroded already?
    Jul 2012
    Lakewood, CO
    Didn't seem corroded when I started messing with it. Damn thing didnt want to come loose and i gave it hell trying to break it loose.
    If its return you maybe able to use a rubber line to splice in. I am not sure what the return pressure is on our cars. Seems like you split the tubing pulling on it or the gas tank.
    cygnus x-1's Avatar
    Chicago area
    The return pressure is essentially zero so you can splice in a rubber line if you have to.
    C|
    Jul 2012
    Lakewood, CO
    now that its daylight, i'm going to jack up my car real high and look and see how its leaking. i'd rather not splice in a hose to bypass that fitting
    Okay I went out and tried to tighten that fitting and it started leaking on me. I even stared at it a minute to make sure I was actually tightening it. So I guess I get to get rid of it.
    Just wondering, is that a compression fitting?
    May 2010
    Alabama
    If you are talking about the fitting in the bracket in middle of the pic - that is NOT the return line - it is the main fuel line part number 17707-SE0-931. Not sure why you are not able to get it loose - but be sure you are turning it th right way - easy to get messed up under a car and looking at it backwards (been there). The hose part looks to be fixed/welded to the bracket. The part that unscrews looks to be a large version of a flare nut used on brake lines (left side of braket in the pic). Put plenty of Liquid Wrench (or equiv) on it and use a flare nut wrench and lock a set of vise grips onto the bracket as a holdback. Work it back and forth - flare nuts should spin around the tubing as they unscrew, but they love to get stuck to it and twist it into a pretzel.
    Good luck!
    May 2010
    Alabama
    item # 6 in this diagram
    1 16912-SE0-931 DUST SHIELD, FUEL HOSE JOINT (NOT AVAILABLE) JPN, USA 1 -- -- *
    2 17574-SE0-000 GASKET, BASE JPN, USA 1 $7.43 $5.39 *
    3 17701-SE0-000 RUBBER, FUEL PIPE INSULATOR (NOT AVAILABLE) JPN, USA 2 -- -- *
    4 17702-SE0-931 HOSE, FUEL PIPE RETURN (NOT AVAILABLE) JPN, USA 1 -- -- *
    5 17704-SE0-930 HOSE, FUEL TANK RETURN (NOT AVAILABLE) JPN, USA 1 -- -- *
    6 17707-SE0-931 HOSE, FUEL JOINT (NOT AVAILABLE) JPN, USA 1 -- -- *
    7 17708-SE0-931 PUMP UNIT ASSY., FUEL
    Replaced by: 17708-SE0-S30 JPN 1 $342.53 $248.33 *
    7 17708-SE0-S30 PUMP UNIT ASSY., FUEL JPN, USA 1 $342.53 $248.33 *
    8 17731-SE0-930 JOINT PIPE, FUEL RETURN (NOT AVAILABLE) JPN, USA 1 -- -- *
    9 90020-PD6-000 BOLT, SEALING (12MM) JPN, USA 1 $3.28 $2.38 *
    10 90428-PD6-003 WASHER, SEALING (12MM) JPN, USA 2 $3.02 $2.19 *
    11 90668-SE0-930 CLAMP E, FUEL PIPE (NOT AVAILABLE) JPN, USA 2 -- -- *
    12 90671-SB2-003 BOLT, FR. FENDER JPN, USA 2 $4.57 $3.31 *
    13 91406-SL0-931 CLAMP, FUEL HOSE (15.5) JPN, USA 4 $6.10 $4.42 *
    14 92101-06016-0H BOLT, HEX. (6X16) JPN, USA 2 $0.65 $0.47 *
    15 93403-06016-08 BOLT-WASHER (6X16) JPN, USA 2 $0.88 $0.64 *
    Jul 2012
    Lakewood, CO
    thanks for all the insight, I managed to get that line fixed, replaced a pcv valve and she runs great!
  1. oops!
    By denhonda in forum 2geez Accords
    Last Post: 03-24-2009, 12:31 PM
  2. Rust in gas tank spout
    By Scarface in forum EFI Tech
    Last Post: 09-26-2004, 08:43 AM
  3. Oops?
    By 89dxowner in forum Performance
    Last Post: 07-26-2004, 11:56 AM
  4. anti rust systems (rust arrestors)
    By bajanviper in forum 3geez Accords
    Last Post: 08-06-2002, 02:58 PM
