Results 1 to 25 of 40
Thread: 89 Lxi Idle Issues. Help!
    Oct 2012
    1989 Honda Accord Lxi
    Lynwood, Ca
    So this past sunday I changed my distributor since I needed a new one. After I changed it, suddenly my idle started acting funny and going from 1100-1800 after warm up. I wondered if it had anything to do with my Distributor cap gasket. I took the old one off my old dizzy since I didnt get one with the whole new dizzy I ordered(lame), but when I took it off it was brittle and broke so I had to glue it till mine comes in the mail. So far I checked for vac leaks, bled the coolant, try tapping the IACV to see if it would change idle, and check the round plastic thing under the FITV and it is all the way down? What the hell is going on here! Has anyone else had this problem, and if so how did you fix it?
    Re: 89 Lxi Idle Issues. Help!
    Did you put the dist timing back where it was before?
    Try disconecting battery, also bleed the coolant at over 1500 rpm so it has a nice little stream, oh an do that after the themostat has opened.
    If that dont do it the idle valve may need cleaning off the car.
    Oct 2012
    Lynwood, Ca
    yea, the dizzy timing is fine and dizzy works great, I figured maybe the gasket could of did that since I put on my old one that was broke in peices and I had to glue it together till I get my new one in the mail.
    What do you mean by bleed the coolant after 1500 rpm? I did it how EricTheCarGuy(youtube) suggested which was open the bleeder with car off, fill radiatior till coolant comes out the bleeder, retighten it, then start the car with heater on till it reaches normal operating temp then top it off. Didn't really help but also my coolant fans come on when the car does(bought it like this), dont know if that will make a diff or not..
    Dec 2003
    Millington, TN
    It could be related to a number of different things. The old dizzy was so shot that the new one needs to be adjusted.
    Is it trying to stall?
    Do you have the correct distributor?
    Did you notch the dizzy to the head before removal or are you adjusting with timing light (15 degrees BTC)?
    1100-1800 rpm, is it surging from 1100 to 1800 repeatedly? That sound like a vacuum leak.
    Phil
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Idle bouncing between 1100 and 1800 rpm sounds like a vacuum leak; mine did the same - brake booster broken when I bought it.
    Check and double-check for vacuum leaks. It has to be somewhat important because a small leak would make the idle faster but not bouncy.
    Oct 2012
    Lynwood, Ca
    @nswst8 - Yes the old dizzy was super shot. You could tell it was the orig or just just super old. It's not trying to stall. It starts and runs great, it's just the surging between 1100-1800 when warmed up. Either that or it just stays at like 1100 idle. The dizzy is the same and was put in perfect. Yea it is doing the constant surging when I'm at a light or in neutral. Maybe it is a leak but I have to check again tho I checked 4 times already. Keep in mind what I said about the DISTRIBUTOR CAP GASKET too tho. It was off the old dizzy and was hard and brittle. It actually broke and had to be glued to put in the new one. Idk if that will affect it, but I have a new one coming in the mail in a few days
    Oct 2012
    Lynwood, Ca
    @ecogabriel - Brake booster broken? How can you tell that or what are some symptoms of a bad one
    Apr 2008
    Atlanta, GA
    brake pedal was hard to operate, I could feel the noise of air rushing in
    Dec 2003
    Millington, TN
    Idle air adjustment is needed. Disconnect the 2P connector at the IACV adjust the idle air screw 650-700 RPM. This will cause check engine light to come on just pull the #11 fuse for a minute. My idle air screw was nasty when I pulled it, which led to a thorough throttle body cleaning.
    Being that the dizzy was toast some drastic idle adjustments may have been made that you will have to correct. The IACV will need to be removed and cleaned. A good throttle body cleaning will be needed as well.
    Remember that this is a 20+ vehicle and alot of maintenance will probaly need to be addressed.
    Do all the basic tune up maintenance and then go from there.
    Phil
    Oct 2012
    Lynwood, Ca
    Quote Originally Posted by nswst8 View Post
    The 2p connector? By doing this, how would I adjust it to 600-750 if the idle is bouncing up and down? Won't it stall out? Should I reset my computer too? I did the basic maintenence stuff tho and just got this car last wknd. Changed dizzy, new cap and rotor, spark plugs, oil, filter, and wires are good. And this number #11 fuse for the CEL, is it in the box under the hood or in the car?
    Oct 2012
    Lynwood, Ca
    Also this Idle air screw you mention, your talking about just the screw that adjust my idle correct? Your talk about pulling your idle screw kinda threw me off a bit
    Dec 2003
    Millington, TN
    Correct, Idle screw is at the top of your Throttle body opening. It is a brass screw next to a red braided vac hose. Sometimes the rubber o-ring deterioates and some people use some type of goop to seal and set it.
    You will have to remove the Idle screw to thoroughly clean it and the port it screws into.
    #11 fuse is in the under the hood fuse box.
    I would start by cleaning the throttle body and then the IACV. Check for vacuum leaks Then adjust the idle.
    Phil
    The bouncing idle is a classic symptom of a vacuum leak. If it started immediately after your distributor swap, then check your install. Specifically, look at the vacuum advance diaphragm. Look for leaks and make sure the vac lines are installed properly.
    The cap gasket will not make a difference.
    Oct 2012
    Lynwood, Ca
    It didn't start immediately after, I would say more so later that night. It starts and runs fine and did right after I installed it, and it sits in properly. I will say that I did try to start it when I put it on forgetting to put the coil wire back on, but it doesn't seem like it affected it.
    Dec 2003
    Millington, TN
    If in fact your idle does bounce, that is a sign of vacuum leak/s. Since you are in CA it has meet smog in the past.
    I'm still at the conclusion that there are a number of maintenance issue that need to be addressed.
    Phil
    Oct 2012
    Lynwood, Ca
    The cars already been smogged and taken care of so I'm good with that. I checked like a million times for leaks and found nothing, and I have the IACV off and cleaning right now. it's just weird it started after I changed and put on a new dizzy
    Dec 2003
    Millington, TN
    It is possible that the dizzy is bad. I believe that Autozone has the ability to test out the dizzy.
    Phil
    Oct 2012
    Lynwood, Ca
    That would suck if the dizzy is bad when I just bought it. I just cleaned the IACV tho and no more bouncy idle. Now I just have to adjust the idle now tho. It's at 1100 steady and I cant get the damn idle screw loose haha. I think the person with the car before me deff adusted the shit out of it
    the adjusting screw needs tweeking now probably since the new part makes the car run better at idle? It is trying to find correct speed but cant because it is so far out of the range of adjustment...
    Dec 2003
    Millington, TN
    Quote Originally Posted by pacmannproductions View Post
    Okay, you are making progress. It seem that the adjusting has been sealed in place by some type of goop.
    If you have a impact driver (not impact gun) you can try that. If not use a screw driver and a hammer to try and break loose the Idle adjusting screw. Do not whale on it, just tap while trying to turn the screw counter clockwise. Heat might help as well.
    Phil
    Oct 2012
    Lynwood, Ca
    It actually started doing it again later tonight :-/. Being that it stopped most of the day after I cleaned the iacv, do you think mines juat done and needs to be replaced? This is annoying
    Dec 2003
    Millington, TN
    Well, as much as I hate to say it. Yes you are looking at 20 year plus part. but also a good cooling system cleaner might help. It all depends on how well the cooling system was cared for. Was the IACV real dirty or gunked up. Rusty water present or not?
    Phil
    The bouncing idle has been covered (and solved) a million times over on this board. Stop chasing rabbits and fix either your vacuum leak or bleed your coolant properly.
    Oct 2012
    Lynwood, Ca
    It actually wasnt gunked up but it was rusty and dirty. The holes on each side still have room to flow. Its not like my last car(integra), i took that off and the joles wete basically gunked shut. But yea, you think maybe replacing it would be best, cuz like I said it was working n idling good all day after i cleaned it till last night it started again.
    Oct 2012
    Lynwood, Ca
    I've read its been solved a million times but I've tried all the ways solved and it hasn't worked, so I'm trying to get help here. I bled my coolant right and ive checked multiple times for vacuum leaks. I just dropped it off at the shop tho so hopefully they can help me out
  1. 89 Accord LXi idle issues
    By pacmannproductions in forum EFI Tech
    Last Post: 10-13-2012, 05:07 AM
  2. High idle issues only once in a while, need help
    By Sofmech in forum Carburetor Tech
    Last Post: 12-19-2009, 12:46 AM
  3. idle issues
    By evil88accordLX in forum 3geez Accords
    Last Post: 02-15-2008, 10:48 AM
  4. Idle issues
    By Steve_Si in forum 3geez Accords
    Last Post: 03-22-2007, 04:34 AM
  5. idle issues
    By alboy in forum Carburetor Tech
    Last Post: 06-21-2004, 12:23 PM
