Results 1 to 10 of 10
Thread: rack n pinion
    Oct 2012
    Portsmouth
    rack n pinion
    ok was looking for steering fliud leak and found hose hanging off and no boot around rack on right n left boot busted. wondering if i should just replace rack n pinion or replace boots n connect line?
    Dec 2003
    Millington, TN
    Re: rack n pinion
    If the rack is not leaking, then just replace the bellows. The hose is the air equalizing hose that attaches between the bellows.
    Phil
    Oct 2012
    Portsmouth
    Re: rack n pinion
    will do..ill check it out. replacing boots would be alot cheaper. i spotted an 87 at pick n pull n it was really clean underneath. would u trust taken parts from there?
    Dec 2003
    Millington, TN
    Re: rack n pinion
    I use junkyard parts whenever I can but you must remember that it is a used part. So use your best judgement.
    Phil
    Re: rack n pinion
    Usually the boots shred because they get loaded full of oil leaking from the ends of the rack. If everything under there is drenched in oil and you're continually losing fluid, then plan on replacing the rack.
    Oct 2012
    Portsmouth
    Re: rack n pinion
    yeah it is a mess under mine, oil everywhere.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: rack n pinion
    As much trouble as it is to replace a bellow & your rack is probably leaking, might as well replace the whole thing with a reman... You will need an alighnment also if you replace the rack & pinion.. You can get it close with marking threads & counting turns on the outer tie rod end & measurements.
    Nov 2000
    Re: rack n pinion
    I got very close to correct alignment specs by marking the garage floor from a plumb line hung from a set point on the steering knuckle. Counting threads resulted in being way off. A short while before my rack puked out all its fluid I replaced the boots. They were plenty wet. How stupid was I for doing that? Of course, I didn't ask here before I did it.
    I had a number of slow leaks that accumulated until I was having to add fluid a couple times a week. Then, one day as I was pulling into my garage I left a trail of fluid all the way up the driveway. If you have leaks in the rack do plan on replacing it.
    Re: rack n pinion
    if the boot is ripped just change it. if it is leaking fluid then the rack seals are bad. I would not use a junkyard rack. There is a lot of labor to replace the rack and I would be pissed if I had to do it twice.
    Eric
    Oct 2012
    Portsmouth
    Re: rack n pinion
    thanks for advice everyone. decided to go new rack. time to search for diy
  1. Rack and Pinion
    By -$MOKIN- in forum 3geez Accords
    Last Post: 04-30-2011, 07:24 AM
  2. Rack and Pinion
    By dalinxz in forum 3geez Accords
    Last Post: 04-23-2007, 11:03 AM
  3. Rack n' Pinion?
    By Chris86Lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-26-2003, 09:44 AM
  4. rack n pinion
    By n_jay78 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-19-2003, 04:28 PM
  5. Rack and Pinion
    By c20v6turbo3rdgen in forum 3geez Accords
    Last Post: 04-08-2003, 10:09 PM
