Results 26 to 50 of 56
Thread: overheating
    LX User stezie's Avatar
    1988 Accord 2.0i 16V (B20A2)
    Co. Donegal, Ireland
    Re: overheating
    I had similar problems with a civic years ago. especially when you mentioned rusty water after giving it a flush. The previous owner to me ran the car on plain water. no coolant. this rusted the fins away completely on the water pump. the water pump was unable to circulate enough water to cool the engine so over heated. You might need to take your water pump out.
    May 2012
    central Ohio
    Re: overheating
    Quote Originally Posted by CzEcHy View Post
    One issue I noticed is rusty coolant still comiing out even after I flushed the entire system for over an hour till every main hose and radiiator ran clear a few times.
    Do you know the age of the radiator? Maybe it's partially clogged and needs to be replaced.
    Re: overheating
    Quote Originally Posted by stezie View Post
    Good point, when I got my motor it was guaranteed to have 50k or less miles on it, the thing was mint. BUT, I did replace the water pump because that is just what you do when you buy used motors. Good thing I did because even with low miles, from sitting around, the impeller and housing was like red clay. Those impellers are stamped steel, little rust breeders...(some were actually cast iron!)
    That sediment can hide in the radiator too, no matter how much you flush it as long as some little bit remains it breeds like an infection.
    The PH will be acidic, and just the flow of the coolant thru the radiator and engine can make it actually take on electric charge. Want to see that? just hook your DVM to ground and set the positive lead in the coolant.
    LXi User Buzo's Avatar
    Dec 2010
    North of Mexico
    Re: overheating
    I am unaware how to jumper the switch properly. Sorry guys
    If somone can howto it for me in their post I will do it
    Detail preferred
    Well, you already replaced the thermoswitch in the bottom of the radiator, so you are familiar with how the connector looks like.
    IMAGINE this is the connector (sorry don't have a pic of the actual one), take a metal clip, make an "U" and insert one tip in each side, just like shown in the picture. Open your ignition Key and the fans must kick in immediately. If so, then your new thermoswitch might be defective or is not rated for the car.
    Power is nothing without control
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    Re: overheating
    K I will check the switch and coolant tonight.
    Nov 2006
    Re: overheating
    Xerex G5 is a good long life coolant to use. Many problems with cooling system corrosion, rust, rusted pump vanes, plugged radiators, blown head gaskets,,, can be traced to not changing the coolant, running only water, etc. The important function here is not just keeping the engine operating temp, but very important corrosion inhibitors with all the various metals exposed in the system. It is what drove the industry to develop long life coolants; nobody paid attention to the fact you had to change your coolant every 2 years! Now we are about 5-10 years for coolant flush and replace for long life coolants.
    ...lets not complicate the problem here though with more issues: the engine temp overheats only when the car is not moving and the fan does not come on when it should. Also, turning on the A/C, (which turns on the fan) will bring the engine temp back down. This all points to the fan thermo not working. Plugged radiator, or faulty water pump possible but should wait until the fan is fixed first.
    Jul 2008
    89 Accord LXI
    Re: overheating
    Jumped thhe rad thermo switch and... fans turned on.
    Jumped the thermo on the thermostat housing, small fan kicked on (with key OUT of ignition)
    Rad switch bad? It was brand new
  8. #33
    LX User 2geeSEi's Avatar
    Apr 2010
    1985 Accord SEi
    Riverside, California, United States
    Re: overheating
    Either that, or you aren't getting enough circulation. The only way to test the switch is to use wire to suspend it over a pot with the probe in water, then heat the water on the stove with a thermometer in it, use a multimeter to see when you get continuity. I should kick in between 195 and 200 degrees. Earlier though, you were saying that the bottom of the radiator was cold after you flushed it. Is it possible that you flushed rust into the tops of the little cooling tubes in the radiator? If so, the best thing to do while you have the coolant drained, is to remove the radiator, hold it upside down, and run water in the lower radiator hose opening (which will now be the one on top) full blast while tipping the radiator back and forth. This will dislodge anything that isn't really stuck in the tubes.
  9. #34
    Dec 2010
    North of Mexico
    Re: overheating
    Is it possible you are getting paranoic? What do you mean with car overheating? Is it blowing water vapor through the radiator cap?
    Fire up your car and let it get to the max temp, the fan should kick in sooner or later.
  10. #35
    Re: overheating
    An infrared thermometer from Harbor Freight can be enormously helpful in seeing what engine temps are really doing. Both fans should be turning on when the radiator fan switch gets to 194* F.
    For what it's worth, you might start budgeting for some cooling system repairs in the near future. I had a rusty system like yours and by the time I was done, the heater core was about the only thing I hadn't replaced.
  11. #36
    Apr 2010
    1985 Accord SEi
    Re: overheating
    Yeah, the infrared thermometers are highly useful.
  12. #37
    Re: overheating
    Well CzEcHy if you never get the issue resolved we certainly have enough material in this thread for anyone else's overheating issues. Keep it going all the way to a intermitant head gasket leak, which can have this symptom as well.
    Infrared thermometer is one of the most usefull tools ever, use it in any trade out there.
    I could start a thread just on what all it could be used for!
  13. #38
    Jul 2008
    89 Accord LXI
    Re: overheating
    Forgive me for sounding 13 in the video. I let the car sit at idle for ten minutes till the gauge started moving then started recording
    http://m.youtube.com/watch?v=qY1gfOZDeO0
  14. #39
    Nov 2006
    Re: overheating
    OK, I'm stumped; Unable to open, load, play, or punt with that video in your link.
  15. #40
    Jul 2008
    89 Accord LXI
    Re: overheating
    Try removing the m and .
  16. #41
    Apr 2010
    1985 Accord SEi
    Re: overheating
    I saw you touch the top hose, have you felt the bottom one at that point? Is it cold, warm, or hot?
  17. #42
    Jul 2008
    89 Accord LXI
    Re: overheating
    Very hot.
  18. #43
    Apr 2010
    1985 Accord SEi
    Re: overheating
    You said that you replaced the cooling fan switch in the radiator. Are you sure you got the A-90 (194 deg) and not the A-108 (226 deg)? Or could there be debris (rust) caked around where the fan switch goes inside the radiator. If both hoses are very hot, it seems that the circulation is good. If you can get or borrow a non-contact thermometer, you can monitor the temp of the sensor directly to see at what temp it is really coming on.
  19. #44
    Apr 2010
    1985 Accord SEi
    Re: overheating
    Just a thought, also check your battery ground to transmission. If the ground is not good, it can cause random problems like that.
  20. #45
    Nov 2006
    Re: overheating
    +1 Most likely it's still the fan thermostat in the bottom of the radiator. It's defective or the wrong temp rating.
    If it was a circulation problem (clogged radiator, bad pump, or thermostat stuck closed), the temp would not drop so effectively once the fan came on and the lower hose would be cooler than the top. Reving the engine above idle (2-3K rpm) will increase coolant circulation and bring the temp down quicker.
    It's tough to diagnose when you replace a part with one that does not work right... one reason I much prefer to order OEM parts from Honda. Usually Majestic Honda.
  21. #46
    Apr 2010
    1985 Accord SEi
    Re: overheating
    He said that he replaced the fan thermostat switch. That was why I questioned which temp rating he put in.
  22. #47
    Feb 2011
    89 Dx, 89 LXi
    New West
    Re: overheating
    Just went through this a couple days ago. It turned out to be a bad/lazy crusted up thermostat. On a whim I also replaced both fan switches (the one on the thermostat housing with the black connector and the one on the rad with the grey connector). I did check the new switches with boiling water and a multimeter to make sure they were good. Even with a hinkey thermostat both hoses were getting hot after 20min of running but still no fan action (one can force fans by flipping on the AC). Was a bit of a head scratcher. I shall meter both old switches when I have some time over the next couple days and post up the results for your general amusement.
    I seem to think the two aren't interchangable connector-wise as well.
    Sent from my rooted Samsung
  23. #48
    Apr 2010
    1985 Accord SEi
    Re: overheating
    I was wondering about that with the connectors, but my 2g only has the one on the radiator, so I couldn't go check it out. He did say that he replaced the thermostat though. If it were me, I would test the new radiator switch with the multimeter, thermometer, hot water.
  24. #49
    Re: overheating
    Thermostats can be put in backwards too. It can drive you crazy if it's not discovered.
    It is weird though how many of these car's fans come on at differnt temp readings on the dash guage.
  25. #50
    Nov 2006
    Re: overheating
    Quote Originally Posted by rdempster View Post
    .............. If it were me, I would test the new radiator switch with the multimeter, thermometer, hot water.
    That's what I would do as well.
    Looks like the fan does finally turn on, (in the video) but way too hot already. Either this thermostat is not turning on at the right temp or there is poor circulation of the coolant. (the test in the video points to the thermostat as the temp comes down quite rapidly once the fan is finally turned on)
    ...we would all like to hear how this is finally resolved. for future reference.
  1. Overheating
    Last Post: 10-29-2007, 04:21 PM
  2. overheating still ...
    By gekko in forum 3geez Accords
    Last Post: 11-08-2003, 05:24 PM
  3. Still overheating, or so it says
    Last Post: 11-05-2003, 07:56 PM
  4. car overheating
    By xaccordx89x in forum 3geez Accords
    Last Post: 08-26-2003, 05:59 PM
  5. Car is always overheating???
    By 86exi in forum 3geez Accords
    Last Post: 07-30-2002, 05:44 PM
