are YS1 gearboxes quite easy to find over there, how much do they go for?!
250-300 I found one in Portland that was rebuild an the guy wants 275Usd
Are you trying to avoid welding the transmission mount? I would recommend against that, there is a lot of weight and power going against that one spot. Keep in mind there are no TQ, or front mounts to help with the weight distribution and TQ distribution. I only used the bolts to line it up, then welded that bad boy on.
it's not like you'll ever want to go back to an A anyway lolz
dead white and blue
yea its more of a auto x tranny or drag. No hyway LOL. ill end up doing the Ls final gear swap.
^^ Yea welding is a good idea for sure on the trans mount. I had my buddy weld it in, and wouldnt have done it otherwise.
Also, my S1 trans was short enough on the highway, I can't imagine what a YS1 would be like... that must suck!
S1 is the shortest gearing of them all, i dont think the YS1 is as bad
Well then... hahaha. Maybe when I get my exhaust fixed it wont suck so bad on the highway, but right now its so damn loud at "highway" speeds.
Ys1 is pretty good or a b16 tranny which idk what the code is for those lol.
Found it....can't wait to see a vid of it running.
i should be running by jan. I have a good aid check coming Lol.
Well now I'm thinking going itbs. Either gsxr or cbr . Cbr have the same tps which make it simple to reformat on Crome . It seems cheaper the. Buying Itr intake an tb.
Honestly ITBs are awesome for all motor, but you have to really invest in a full setup. Fully built head, and block plus an amazing tune. If you don't have that then you are wasting your time. You can get an AEBS intake manifold (identical to the skunk 2, or type R), and be ready to go with a solid reliable setup for half the price.
Umm. Well head is just just Itr valve train an I'm looking for Itr cams. I'm trying to go all motor but if not boost is going to be fun. But ill just get it I found some gsx r 1000s an cbr 935 or something like that for 60 shipped. I'm looking for a DIY type setup which I'm good at. I completey agree thou with your statmeant . But I'll just get it since it's so cheap to do.
B18b1 block honed decked . Ready for some lsv baby
anymore progress??
no girdle on that b18b block?? hmm i wonder if my b20b has one or not. will be required for extra revs
good to see ur engines getting there maaateee
yes sir. Ill post pics as i go. Ill be hitting it hard here soon.
nope no gridle. not really needed. alot of lsv setups didnt have gridle. all that matters is that you swap out the rod bolts since there the same a a d series which cant withstand 8-9k revs. Get arp rod bolts and you can rev high as a gsr all day. Gridle just adds that extra security which is all up to you if you want to add it. Im not cause you would have to have it all redone at the machine shop and have a bigger oil clearance. B16a dont have a gridle and they rev to 8.5 all day its all in the rod bolts.
to awnser your question on the b20. NO there is no gridle on those motors. Only gsr's have gridles. ive been reading alot of lsv b20v setups an no gridle is needed for high revs just rod bolts cause they tend to loosen up and stretch out cause they cant withstand the rotating mass that is put on them. Save yourself the money an get some arp bolts total 50 bucks.
Sweet!! Can't wait. How much whp ya thinkin?
I'm about to venture into the b series motors my self. I'm soon buying a 92 civic 4 door that has a b18b1 in it and the blocks bad. I've been on my search and am prolly just goin to put another B18B1 in It. So someday if I can throw a B18C in it and run vtech I'll be figuring all this shit out too .
178ish who 200hp is my goal all motor
lol
