Come on, just one, don't be greedy!
A20a4
I'll post some this week
Dam I want to see this ish to! I REALLY want a b-series now. It looks bouss. Really though any pics/updates??
Low loud lovin it!
~~~~~~~IG @the_boso_3g~~~~~~~
im saving the pics LOL. takes time to make a nice vid to. im not that great at that kinda stuff so im trying.
Dont worry.
Ooooo like that huh. Oright
How can you have the rep of being a pic whore when you dont post pics.
Cause im on the edge of graduating and studying for my ASE test. ALot of pressure here in last 2 weeks. My career is more important then my car right now LOL.
so ill get at it once i have time. It will be a monster regradless.
Very proud of you Josh! I'm glad to see you have your priorities straight and that you are making something out of your life with a post secondary education. Us paisas have the lowest graduation percentage from HS and even even lower in higher education and you are helping to change that![]()
Gotta break the chain of day labors. I help out when ever I can . I know a lot of shit now that makes passing it on knowing what I'm talking about lol. An thank u homie.
Come on rendon ...What happened dude...Walk out snap a quick pic and post it homie... Were all waitin...
Its good to hear that you're getting your life in order and thinking about the future but you have trow us a bone or something! lol
Lol. Will look I bought some itr cams an blox cam gears . Getting the last pieces tomorrow . Axle starter. Done. So expect a running car in a week or so
Will itr cams are out of the picture. Now it's jun stage 3 cams an blox cam gears plus blox dual dual valve springs an retainers![]()
check H-T in the dragracing section then fs thread, there are some parts in there that may help you out.
getting closer to being done! more pics required.
I know i know guys just hang in there. K here is the final specs of my setup. I just layed down 1500 in parts all headed my direction.
I said Fuck with the BUllshit i want 200 plus all motor straight beast mode.
Power Plant
comp ratio 12:1
b18b1 bottom Decked couple thousands
b1 rods /oversized with ARP bolts
ACL Race main/rod bearings
P30 pistons STD 81mm
Hasting piston rings
Golden Eagle LSV kit
Golden Eagle head studs
B16a head with blox Dual valve springs and titianiam retainers
Blox stage 3 Camshafts Intake Lift/duration:12.8mm 272 Exhaust lift/duration:11.9mm/280
Blox cam gears
Performer X Intake manifold
Onimi 70mm Tb
Golden Eagle Thermal gaskets
450cc Blue tops
b16 water pump an oil pump
Drive train
Y1 JDM Trans
New Bearings and syncros
Exedy stage 1 clutch kit
Fidanza 7.5Lbs flywheel
90-93 DA drive axle new
89 teg pass axle new
90-93 Mid Shaft
Motor will be going in i say bout a 1 week i hope if all parts and hurry up an get in LMFAO.
Till then......................
thats what she said LOL
what its not going yet?? lol
No I needed cams an gears but then I got out of hand lmfao. So in order to run a stage 3 cams the intake mani an valve springs needed an retainers
