Page 26 of 28 FirstFirst ... 1622232425262728 LastLast
Results 626 to 650 of 679
Thread: B18B1 Build and Swap - Rendon LX-I
  1. #626
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: Rendons Offical A To B series thread!!!!
    Makes me to start working on my b series coupe... guess i better stop talking and start working on it behind the scenes.
  2. #627
    Re: B18B1 Build and Swap - Rendon LX-I
    had a great time at the 3geez meet in Seattle this weekend 4.20.13. Put the accord on the dyno and was impressed with the numbers for now. Was detonating pretty good at top end around 7.8k and vtec engagement was horrible as in not smooth transaction feels good don't get me wrong it just robbing me hp when it engages then climbs. over all outcome was
    196.4hp 130tq. not bad cams are set at 0-0 need to bring the LSA closer and tune a bit more on top end. ill post a dyno graph shorty
    Sounds good that red 2nd gen civic looked bad ass
    Wow 130 torque, I bet you don't even need to get on it to stroll pretty good
  4. #629
    It gets up an go forsure here is the vid of the dyno.
    86 Accord lx-i LS VTEC dyno - YouTube
    Vid from a member. He was in the back.
    Rendon LXi | LS Vtec b18 Dyno | 1986 Honda Accord - YouTube
    Was doing some info on my setup I should be 220hp easy it's the fact that Crome free is making me loose a lot of hp. An I need to set intake cam to +2 which I didn't do an vtec engagement needs to set higher for tht dip on the graph to go away.
    I hear that transistion you're talking about, it's almost like it's pulsing in huge spurts but it does catch up.
    If I had to guess, it sounds like an integral flow issue at wot , maybe cam timing since erverthing else is champ.
    What temp does the engine wind up settling in to if you don't me asking?
    It still runs awesome.
    Edit: dam I didnt see that last post till after
  7. #632
    Sits at 190.
    update: Got the accord re-tuned in away its kinda weird thou that at like 7-8.5k tuner said he does slight adjustments and changes he had to keep changing it so he said something is wrong. Only thing i can think of is having the battery in back with the ghetto wire i have. wiring is not a issue or it wouldn't run LOL.
    But im over 200hp now we set peak as in when i drop into 3rd for example i would lean pretty good then richen up. fixed that moved vtec to 5.8k way smoother in transaction. messed with the cams abit. all i gots to say is it moves now i taught it was fast but its faster. ill have to do a follow up vid. All in general its smoother.
    Btw i had a huge vacuum leak. was at 14hg and had a high idle took out the thermo gasket i got and put a oem one. vaccum went to 19hg and the car wouldnt stay at a idle since the tuner set the idle per vacuum leak lol. so the Iacv was correcting my vaccum leak. anyhow i have to do some work on the accord yet as in bushings and what not haven't had any time so busy with family kids and car shows. i redid my wiring as well so its pretty good . ill post some pics but figured ill follow up on my progress.
    That's rad man! I forgot to get a ride in it last time you were here! Gotta get one next time!
    Where's the pics from the shows?!
  10. #635
    Ill post this week an a how to on my pc680'install
    time to bump my some what progress i did to my accord so far.
    installed pc680 battery and i love it . made my own bracket and used the old battery mount to use as a spot. ill have to add pics later i also installed a relay to my fuel pump great mod to improve your overall voltage to the pump.
    https://www.3geez.com/forum/performan...ump-relay.html
    Pics of battery all mounted up! That little PC680 is pretty rad isn't it? I put mine in the trunk and used 1/0 wire up to the main fuse box. Turns over like a champ!
  13. #638
    for sure way better then my ford battery lol. john you asked for pics here you go.
    all done. looks bettery my car acts better. took my time and did it right.
    some random shots i have taken. including better shots of the battery
    comparing size
    mud flaps i bought from john
    my porting job.
    i yet have installed the rear suspension bushings i will do a how to. so just have to be patient
    im lower then you! :p lol im just sayin... lol but how much was that batt? and wehre did you get it from? I need one soon... my walmart one is too clunky in my trunk.
  16. #641
    If you had 300 dollar headers you wouldn't go any lower lmfao. An I'm maxed out on my coil overs . B series is lighter remember . If I had a a20 this thing would drop another 2 inches lol.
    Got it from eBay was the cheapest I found back 5 months ago lol
    pfftt real coil overs, get some :p and how much lighter is it?
  18. #643
    Lighter lets just say that. If I remember correctly I picked up just the block from the ground to the bed of my truck...... Wow that bitch was heavy. An my block to my b series was like a paper I mean one handed status lol.
    bro, did u even lift when u took the A out?
  20. #645
    For sure a considerable difference. Notice any difference in pre loaded jounce riding over dips? Love your car Rendon
  21. #646
    It feel way different to me the swap feel tons better the weight if the a20 would really suck down that front end now I have the b series it feels like a go kart . Front does not bounce as much that's prolly have to do with my coil overs as well lol.
    I'm surprised my kyb's are holding up with these weapon r's.
    Thank you btw
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Nice looking battery man. Looks like its coming along nicely
  24. #649
    it has its been a long road and this car came along ways. its been awhile since you seen it ey?
    DX User Clockworkz's Avatar
    Jul 2013
    1986 Honda Accord LXi
    Las Vegas, NV
    Car looks amazing man. I read up on this thread on a work night and only got 3 hours of sleep.
    And with my lack of knowledge what does the LS mean in LS VTEC? Which is the motor you swapped in.
    Sent from my SPH-L900 using Tapatalk 4
  1. Rendon Lx-I Boosted Sedan Build
    By Rendon LX-i in forum Classic Honda Pics & Videos
    Last Post: 07-27-2011, 12:15 PM
  2. EK Build Up and Engine Swap - '78 Civic
    By redr2 in forum 1geez Tech & Performance
    Last Post: 08-26-2010, 08:06 PM
  3. Rendon Lx-I Boosted Sedan Build
    By Rendon LX-i in forum Project Central
    Last Post: 11-29-2009, 11:38 PM
  4. 88 accord engine re-build vs. swap
    By fish280 in forum General Engine Swaps
    Last Post: 10-09-2002, 12:26 PM
  5. B16A Build & Swap...
    By Honda-Roku in forum General Engine Swaps
    Last Post: 05-29-2002, 06:53 AM
VigLink badge
