Does anyone know where i can get a set of front bumper clear lens. can i just replace the lens or do i need the full lights changed. i unscrewed 2 screws and just the lens came of. thanks
guys please help me.![]()
There were some on Ebay from time to time.
i tried ebay but had no luck, or maybe im typing somthing wrong.
I haven't seen clear ones for the accord. Only ones I seen on ebay are the yellow and white ones in Germany..
http://www.ebay.co.uk/itm/1904709899...84.m1438.l2649
Although thinking back on some website I stumbled across sometime, there was a guy that used some Mitsubishi lens cover to give him clear front lights and he used the coloured bulbs. I cant find the page now im afraid..
them ones in germany are like the standard ones, its almost impossible finding parts for these accords. there must be where i can get them.
iv seen a few but they complete lights with orange in them.
yeah I think the all orange ones are for the aerodecks
is there any way i can get them made clear. its just the lens that needs changing, actual light from inside is clear.
the lens itself is made of yellow plastic.. unless you try and tint them with spray? not sure how that will work out though.
tint will look a bit cheap. need clear ones, its the only way. what about the accord 1 shape after this, will they fit cuz they look pretty similar
I've made 6 sets of clear lenses for the 3gee accord front bumper turn signal lenses. Contact me in a private message or email me at [email protected].
I've got exactly what you want.
Shaggy
FF II/ETC I
And they're made from Lexan, not plexiglas. Plexiglas isn't very useful in the sun over time. These lexan lenses work great though
Shaggy
FF II/ETC I
the one on mine has 2 lights fitted in one lens. one is for side light and the other is indicator. does your lens stick out just like the standard ones as your lens look flat, so won't it be pushed in slightly. the standard lens has edges to it.
They're flat. I love mine. Never had an issue.Those washers that look big, are because i lost the originals and found those temporarily in that pic.
Shaggy
FF II/ETC I
If I remember correctly, you can also use the lenses from a first gen CRX.
are you talking about the 1991 crx. don't think you can buy seperate lenses as they come as complete light. so will the lights fit straight on.
i just seen these lights but they for an aerodeck, i know they will fit but they only have 1 bulb in them, mine has 2, 1 is side light and other is indicator. anyway i can modifiy these.
http://www.ebay.com/itm/5-RECTANGULA...90433793440%26
Crap, totally forgot you were looking for an 89 Accord. You can heat the facelift light housings with a heat gun on low to separate them, then you can pull the orange reflector out of the housing. I did that to a set one time. I can't remember where that set of housings went, though.
i did vanilla sky method too. i went to the junkyard and picked up 2 good looking pair of lights. took a heat gun to it and loosen the front lens take out the orange reflector and added a LED bulb but i like the way frantik did his. https://www.3geez.com/forum/showthrea...nals-installed
he took his apart and the yellow reflector he painted it with some ventshades to tint it and you can still use the stock bulbs.
