Results 1 to 14 of 14
Thread: New guy from Southwest Missouri, 88 Accord LX
    Dec 2012
    1988/Honda/Accord LX
    Iowa
    Hello everyone, I have an 88 Accord LX, carbureted manual that up until a few months ago was my first and only car for 10 years. Incredible piece of engineering. The only significant problem now is that the fifth gear whines when engaged, so I've been using another vehicle as a daily driver, preventing it from getting worse, until I save up to do some transmission work. Just hate the idea of getting rid of it. Anyone have any ideas?
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Re: New guy from Southwest Missouri, 88 Accord LX
    Welcome! It might not have enough oil in the transmission. Have you done a fluid change?
    1989 Honda Accord LX-I 300K+
    Build Thread
    Dec 2012
    Iowa
    Thanks obdriver! Yeah I've done 2 fluid changes in the last 40,000 miles. The sound was really bad before the last change, its almost gone away now--sounds like a faint whining sound when engaged. A transmission shop suggested putting gear oil in? The mechanic that did the 2nd to last change said he found gear oil in it too. (I'm 3rd owner) Does that do a better job than plain motor oil?
    Mar 2012
    1988 Honda Accord LX-i 2 Door Coupe 5 Speed
    Charlotte, NC
    Gear oil will absolutely DESTROY 5th gear and eventually more of the transmission (it is way too thick), only use plain motor oil or Honda MTF!
    Dec 2012
    Iowa
    Dang! This is good to know. Sounds like that's what I've had go wrong. Thanks man!
    Mar 2012
    Charlotte, NC
    Well, you could always get a good used 5th gear from the junkyard, and just buy a new locknut for the mainshaft or countershaft (or both, depending on how bad it is since the nuts are one-time use only, i wouldn't risk it coming off), you only have to take the end cover off (accessible from passengar side wheel well) so it isn't that difficult to do
    Dec 2012
    Iowa
    Thanks zenapup! So you're saying I don't have to do an R&R on the transmission?
    Mar 2012
    Charlotte, NC
    Nope, I've included the page out of the service manual showing the exploded view of the half of the transmission containing the 5th gear assemblies and some other stuff, your only problem will be getting the gasket for the end cover, but I have one if you want to buy it from me, since i bought a gasket kit (last one in existence when I rebuilt my transmission a few months ago) and didn't end up needing the gasket.
    You can use RTV in place of that gasket.
    King Peetis's Avatar
    Atlanta, ga
    Quote Originally Posted by zenapup View Post
    What weight? Will draining the oil be good enough before adding motor oil or should I flush to eliminate contamination?
    It looks like there is only 1/10th of a quart that stays in the trans with a drain and fill, so a drain and fill should be enough.
    The deal is that fifth gear sits at the very end of the mainshaft. There is no oil pump, per se, in the trans and the only oiling hole is about 3/32" in diameter. The oil has to travel the entire length of the mainshaft before getting to 5th and won't get there if the oil level is low or if the oil is the wrong weight. It's a minimalist design that works well if you maintain it, but doesn't leave a lot of room for error.
    Mar 2012
    Charlotte, NC
    Here's a chart:
    Dec 2012
    Iowa
    Hey zenapup, any chance you still have that gasket? Let me know ASAP.
    Thanks!
    Mar 2012
    Charlotte, NC
    Yep, I still have it. $4 plus shipping, probably wont be that much. See service manual here: http://honda.roadpwnage.com/manuals/...-1989-full.pdf (see page 340 for the one i posted earlier). Let me know where to send it and ill get a cost tomorrow and let you know so you can send it through PayPal if that works for you.
  1. anyone up for a missouri meet/carshow?
    By oneslammedlxi in forum Classic Honda Community Chat
    Last Post: 05-22-2004, 12:55 AM
  2. Any 3geez from Missouri?
    By ohvee_89accord in forum Classic Honda Community Chat
    Last Post: 06-27-2003, 09:46 AM
  3. The Tightest 3geez Accord In Saint Louis,missouri
    By LeAndre' Purley in forum Classic Honda Pics & Videos
    Last Post: 03-18-2003, 08:24 AM
  4. The Tightest 3geez Accord In Saint Louis,missouri
    Last Post: 03-13-2003, 03:37 PM
  5. Around Saint Louis Missouri, I need a friend
    By 3rdGenMartyr in forum Classic Honda Community Chat
    Last Post: 09-05-2002, 06:55 AM
