Results 1 to 19 of 19
Thread: front end modifying
    May 2012
    89 lxi hatch
    front end modifying
    Ok is there anyway to convert are headlight from the Winker lights to the modern still light like the ones off of the cb7 our acuras
    Re: front end modifying
    yes. there is the factory way which is mostly a bolt on swap, headlight brackets need to be welded on though. depending on where you are, finding the parts may be difficult
    or the more custom way of putting the CB front end on. not a bolt on swap and will require quite a bit more work to do properly. it's been done before
    May 2012
    89 lxi hatch
    Is there a how to on thethe cb swap an is there someone on the form that's already done it an what all would i need to do the swap besides the cb parts
    Quote Originally Posted by romonharvey View Post
    no
    yes, hondaman87 owns(/owned?) the hatch above
    the ability to do all the fabrication required to make it work or pay someone else to do it for you
    May 2012
    89 lxi hatch
    The fabrication is easy i just need the parts list an ill go from there an thanks for the help
    Its hard to make a list for that.
    Front bumper
    bumper brackets
    bumper reinforcement
    headlights
    headlights housings
    lower blinkers
    all associated wiring and bulbs
    pretty sure none of that will just bolt up, that is where the fabrication will come into play.
    May 2012
    89 lxi hatch
    Ok so in ur own opinion would it be easier to use a Integra front end or a cb7
    In my opinion I think the factory front end looks great. If your talking about the second gen Integra it is going to be just as difficult as the cb7. What is your reason for wanting non popup headlights? Maybe you should just buy a different car?
    went digging and found this Teg frankenstien
    http://www.cardomain.com/memberpage/473774
    i think the da front doesnt look too bad http://www.cardomain.com/ride/258290...-honda-accord/
    yeah maybe if it had a stock bumper it would look even better.
    DX User seancmadison's Avatar
    Jan 2013
    1988 honda accord dx 30,000 mile 1.8 replacement
    willits ca
    I need to speak with who ever did the 80s 3door lxi with 90s front end i have a welder and whole 90sfront front clip.
    Jan 2013
    willits ca
    I may be new but is this not a modify front end page. Cause if i wanted stock id go and look in the repair guide. But i hate going down the road with really dim lights i live in the mountains of Mendocino Forrest. I need to see and buy a different car u wanna pay for it last time i checked 3gs were cheep and reliable so why not at least try and help for those like me loking for a how too on just that.
    Quote Originally Posted by seancmadison View Post
    Well first off, if you buy a car cause its cheap then front end conversations are out as they will require a lot of money. If your headlights are dim, buy some upgrade lenses and install and HID kits. That will be just as bright as any modern car. The reason there is nothing to chime in on is, it will all have to be custom. The only bumpers that get close to "bolting" on is the 1g Integra, but that car has pop-up headlights. Anything else will need to be custom trial and error.
    I remember when I first got a 86 dx, the silver car I usd to have had very poor lighting. I discovered the headlights wern't even halogens. I bought standard H6054 bulbs and made a heep of difference. Upgrading to HID would be even more phenomenal.
    Jan 2013
    willits ca
    I was given free front end im mechanicay inclined just want a second opinion
    Sounds good, take pictures of progress and stuff and post them up! I'd like to see what it turns out.
    Hey I like to see a tailight conversion too since there are aftermarket versions for the 4 th gen but not 3rd gen accords.
    Even the halogens degrade over time. If you haven't already got your heart set on a front end conversion, you could probably get decent light by buying new bulbs and re-aiming them.
    Jan 2013
    willits ca
    I have seen people mod sock tail lights with a template to makesure all lights still legally shine and mold the rest with bondo not best but works
  1. thinking of modifying my engine
    By ShyBoyCA6 in forum Performance
    Last Post: 12-18-2009, 06:47 PM
  2. Modifying Profile
    By bank2me in forum Classic Honda Community Chat
    Last Post: 05-22-2008, 08:08 PM
  3. DIY harness modifying(for those going MS)
    By newaccorddriver in forum Classic Honda Pics & Videos
    Last Post: 02-12-2008, 03:17 AM
  4. Question about modifying a 4g dizzy to bolt up...
    By Secondaries in forum Restoration & Custom Fabrication
    Last Post: 08-18-2007, 12:47 AM
  5. Minor Modifying ?uestion ?
    By Veedubya in forum Performance
    Last Post: 02-21-2003, 09:35 AM
