Okay Doing Rotors and pads next weekend. Rotors are quite thin and the right side brake pad is starting to dig into the rotor. I know its bad but anyways.... Looking at reman calipers. while im changing rotors should I pick up some advance auto parts fenco reman calipers and replace them? after I get the core charge back ill be spending about 50$ on them. 25$ a piece sounds like a steal to me. And I never have actually completely changed brake fluid can anyone describe in detail how to do it? I experience brake fade. For example if im stopped on a hill and I keep constant pressure on the pedal my foot sinks slightly and I need to push down harder to stay stopped and I need to fully release the pedal and push the pedal again to stay stopped. so usually going down big hills I keep in a lower gear and pump the brakes instead of constant pressure. Can this be caused by thin rotors? I feel like it could be the master cylinder but Id much rather start with new fluid and see what that does for me. Ive owned the car for about 3 years now only needed on brake job and I know the back brakes and drums are fine. just the rotors and pads up front need to be done so to sum up....
1) Should I put in re manufactured calipers?
2) How do I change the brake fluid successfully.
Sorry I looked everywhere on the fourm of how to change fluid I really dont like this new search feature![]()
