Hey guys,
I did my alarm a while back, it's basic but does what I want it to...mostly. Keyless entry was easy, I've never had a problem with that. Shock sensor works pretty well. Warning light blinks perfectly (mounted in empty dash panel next to Cruise Control).
Here's my issues, and these should be pretty easy for you guys.
Immediate:
1: No dome light trigger of alarm
--Where do I find this wire, and can I just hook it straight into the alarm wire meant for the dome light? Any relay needed?
2: Alarm siren randomly only makes muted "ark, ark" noise when arming / disarming
--I believe this is due to my shitty power connection for the brain. Where do you guys splice into for power, and how?
Optional:
2: No horn honk, only alarm's proprietary siren
--Can I hook the wires for the alarm's siren to the car's horn directly? This seems like it wouldn't work when the alarm actually went off, because the siren does all those other "WhhhhOOOOOO!!! WhhhhoooOOO!!" noises and I'm pretty sure the car's horn can't reproduce those?
--On my dad's Honda his car horn just goes apeshit in a random pattern (his was installed professionally). This would be fine for me (hell, it draws more attention anyway).
If you can tackle any of these, I'll gladly listen!
