Results 1 to 6 of 6
Thread: Belt Squealing, Deep Loud Engine Noise, Trouble Starting
    Mar 2010
    I'm not sure if these problems are all related. The belt has been squealing for a few weeks, usually just at startup. Will keep going usually until I make it off of my street.
    Then I started having some trouble starting the car. I would have to hold down the gas for a few seconds until the engine gets going or else it would go dead. I pump the gas 3 times and hold it a second each time whenever I start the car, have done this as long as I've had the car.
    Then last night, when I get a little ways from home, it starts making a noise it's never made before. The engine became louder and started sounding, I guess, like a tractor or something. The noise seems to be coming from the driver's side, underneath the hood.
    Any ideas? Do I have three unrelated problems?
    Sep 2012
    Re: Belt Squealing, Deep Loud Engine Noise, Trouble Starting
    Fuel injected, or carborated?
    Sounds like a defective water pump , is it overheating? If that belt is so loose it would not turn the water pump well which would cause overheating or close to it.
    Is it froze up when you start it?
    Wp
    Vid of noise?
  1. squealing belt?
    Last Post: 11-27-2012, 03:32 PM
  2. 89 LXi squealing alt.belt
    By teverson-sr in forum 2geez Accords
    Last Post: 09-03-2010, 04:59 PM
  3. squealing noise.. help
    By jstyle711 in forum 3geez Accords
    Last Post: 07-11-2003, 12:57 PM
  4. loud clicking noise in engine compartment!
    By Sharky196 in forum 3geez Accords
    Last Post: 03-31-2003, 08:16 PM
  5. squealing belt
    By slammedLXI in forum 3geez Accords
    Last Post: 03-06-2003, 05:37 PM
