Results 1 to 3 of 3
Thread: small diameter red colored braided hose from fuel filter to EFI intake?
    You know which hose Im talking about? Its red, small diameter, braided with metal clips at the ends and it connects the fuel filter at the firewall to the EFI aluminum intake, just above the U-shaped air tube from the air filter box. I broke it in removal of the engine, and Im not sure if you need to buy an exact honda replacement for this hose, as it seems to be special construction? Or can a guy buy generic rubber hose of similar ID from autozone?
    Re: small diameter red colored braided hose from fuel filter to EFI intake?
    Dashpot port!! Just found it in the manual. what do you use as a replacement for this hose? mine is knackered....
    carotman's Avatar
    Montreal South Shore
    You can get any rubber hose that's rated for gasoline use.
    This is for the evap canister
    I need these parts!
  1. small coolant line/hose replacement
    By G. White in forum 3geez Accords
    Last Post: 08-12-2015, 06:42 AM
  2. Small gas leak...is it the fuel filter?
    By SeanSelander in forum EFI Tech
    Last Post: 05-13-2012, 12:48 PM
  3. need hose diameter for bulk hosing help
    By xxxfrankensteinxxx in forum 3geez Accords
    Last Post: 09-20-2008, 08:38 PM
  4. Stainless steel braided hose kits???
    By nskforlife in forum Interior & Exterior Care
    Last Post: 11-26-2006, 05:49 PM
  5. A slight problem with a small radiator hose
    By 89AccordLXI666 in forum Carburetor Tech
    Last Post: 05-12-2003, 08:40 AM
