Results 1 to 4 of 4
Thread: batttery light came on / temp started bouncing
    DX User Edward Ochoa's Avatar
    Nov 2012
    1989 hondaACCORDLXi
    Phoenix, Arizona, United States
    i went to auto zone and go-t the car checked and nuthing was bad starter good, battery good and the alternator is all good that passed and now im thinking that turn-signal switch is gone bad i mean i put the fuse's back in the turn signal but when i use it pop the fuses go then i have to replace more is easy just to replace the switch and thats that or should i take it to the electrician and spend money out the ass just to tell me what i know
    tyhe temp gauge is bouncing around it hella cold here and when i started it and let it run when i took off it started move to hot and then down and lower then all of a sudden i push the gas pedal then it shot back up but the thing no overheating its just got rebuilt the Eng so meaby a faulty wiring or something not reading
    Re: batttery light came on / temp started bouncing
    Quote Originally Posted by Edward Ochoa View Post
    Well, the switch is ~$250. If you can find one. The easiest is to rebuild the switch yourself following the How-To articles.
    Rebuild the headlamp switch: https://www.3geez.com/forum/how/60916...mp-switch.html
    Rebuild the wiper switch: https://www.3geez.com/forum/how/77873...g-rebuild.html
    Here is what I found when I rebuilt mine: https://www.3geez.com/forum/technical...h-rebuild.html
    It costs pennies to rebuild and delivers a lot of bang for the buck. My switch is working wonderfully well now.
    There is a single wire connector on the thermostat housing neck going into the head. It is on the back, closest to the firewall. Make sure that the connector is tight, not flopping around and that the wire isn't broken or frayed. If that doesn't make good contact, you'll get erratic temp readings.
    I'm not sure what the issue is with your battery light, but the free tests at Autozone are worse than useless. They tend to pick any random part and call it bad. After you have spent money replacing it, you find out that your original problem remains.
    Here is a video from Eric the Car Guy that outlines how to check your charging system: https://www.youtube.com/watch?v=FTGz0PKIl84
    You might also want to load test the battery. You'll have to pick up a new tool to do it properly though (~$25-50 from Harbor Freight): https://www.youtube.com/watch?v=3QiKyjWWiRo
    Let us know what you learn.
    Nov 2012
    1989 hondaACCORDLXi
    okay i will try that can you point me to the how to take off the steering wheel as well also does that go for the blinkers switch as well ???
    Nov 2012
    1989 hondaACCORDLXi
    o did what you had said to do and hopefully it works for while the first try it popped a fuse then replaced it with a new one and now it works thank you very much my inlaws wanted to take it to the shop again??? but i got you guys for help 3GEEZ FOR LIFE !!!!!!!!!!!!!!!
  1. Bouncing Tachometer
    By Alexi3rdgen in forum 3geez Accords
    Last Post: 12-16-2009, 02:30 PM
  2. Caliper bouncing!
    By McNick in forum 3geez Accords
    Last Post: 12-26-2003, 07:45 AM
  3. Bouncing water temp gauge
    By microracer in forum 3geez Accords
    Last Post: 10-10-2003, 10:10 PM
  4. bouncing speed-o
    By 89accord_lxi_coupe in forum Performance
    Last Post: 07-05-2003, 01:19 PM
  5. Replies: 2
    Last Post: 03-28-2003, 11:24 PM
