thomson85
I agree with dr. Snooz. Check your electrical. Since you stated that you replaced those components just prior to this issue, then most likely this 'bottoming out' issue just either knocked something loose. Also, you said you replaced the distributor. If its not seated all the way, this will cause a no-start condition. Either way, get a spark tester. They are only a few dollars at the parts store.
Also, please take the time to write properly. You have run on sentences, making it difficult to understand what you're saying. I know typing on a phone sucks. But I wrote all this on my phone. Don't use swipe if its an issue, i don't. A good example is you keep saying cat when I believe you mean car. Saying cat will make me believe you think the catalytic converter is bad. Put your hand over the exhaust, if you feel pressure while someone is cranking then that's not your issue. CHECK YOUR ELECTRICAL (IGNITION). Something you replaced right before this happened (as you stated) probably came loose or was not installed correctly (dizzy).
