Hey guys, having a bit of an issue.
Finally getting everything ready to go on my 88 DX sedan. Went to start it and it wouldn't start. Realized it was out of gas. Put a couple gallons in and it would start and immediately stall.
Realized the throttle stop screw was waaaaay too far out. Screwed it in as far as I could and it started and stayed running. Cool, right?
Went to drive it around a bit, and as soon as the temp gauge started to go up, the car stalled. Would start if I pump the pedal, but then stalled. Now it seems it will start and stay started for a couple minutes, and then will stall after warming up.
I don't /think/ the primary cut-off slow mixture solenoid valve (or whatever) is bad, but I haven't checked it. Plan to tomorrow. Also I will change the rear fuel filter, as I haven't changed that yet. I am fairly sure that the idle mixture is off, but the manual assumes that the vehicle will stay running once the engine has warmed up in order to perform the procedure, which is exactly my problem.
Any suggestions?
