Results 1 to 3 of 3
Thread: sputtering low rpms.
    Mar 2010
    88 lxi
    lawrenceville, GA
    ok so the past few days ive been trying to fix my newly developed sputtering idle/ low rpm. basically at idle it will have a misfire like symptom that causes it to backfire every 3-8 seconds. this sputtering also continues until about 3000 rpm. but the higher it goes into the rpm range the more faint it becomes. im getting a code 9 cel so i replaced the following things:
    dizzy ( used but i know it was good because it came off a buddys car that ive driven)
    plugs
    wires
    fuel filter
    i have also
    checked timing
    adjusted dizzy to every degree possible
    filled up
    added fuel additive (free at work )
    compression test (consistent across the board )
    anyways, the only few things i have left to try before i give up and buy a brand new dizzy (200$ :/) is, fuel pump possibly or the resistor type thing that grounds on the pass side of the bay and has two leads going to the coil and harness
    anyone else have any input as to what else to do in this situation?
    88 lxi:
    Mar 2010
    88 lxi
    lawrenceville, GA
    Re: sputtering low rpms.
    Bump?
    There is a troubleshooting sequence for a code 9 (Crank Angle Sensor) in the manual. You could have bad wires going to the dizzy or bad ground. Run through the sequence and see what you come up with.
  1. new: 87 Accord, sputtering
    By zorobyte in forum Carburetor Tech
    Last Post: 06-12-2009, 05:27 PM
  2. sputtering/hesitation
    By 86-accord-lxi in forum EFI Tech
    Last Post: 08-15-2007, 04:13 AM
  3. Tries to die when I accel, sputtering
    By jigga225 in forum 3geez Accords
    Last Post: 08-06-2005, 07:17 AM
  4. Yet another one of those sputtering problems
    By Busted_Blue in forum EFI Tech
    Last Post: 07-16-2005, 05:33 PM
  5. sputtering
    By adams86lxi in forum Classic Honda Community Chat
    Last Post: 03-11-2004, 08:34 PM
