Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
Thread: energy suspension bushings ALL.
    Re: energy suspension bushings ALL.
    here's the hard poly upper control arm bushing kit Web Store
    Apparently that's a set to do both sides,I thought it was one side,good deal there
    Just wanted to confirm that the rear lower control arm bushing works. Everything on this list works
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Sticky
    agreed
    DX User Jacques's Avatar
    Jul 2015
    Bend, OR
    will i was comparing the rear lca bushings with with a new bushing from honda . its a no go the sleeve on the Rear Lca kit is to big..............
    BUT...........
    if you take apart the bushing (prothane kit 8-312) the bushing it self fits the stock sleeve after knocking out the rubber and metal tube. You will have to untapper the stock lca bushing sleeve to get the Prothan insert to fit. Bing bam done. ill have to post pics. but just wanted to throw that out there. ive compared should fit no problem. (i have a new stock rear lca bushing)
    Are you still around? What do you mean by "untapper the stock lca bushing sleeve"
    I have the 8312 set of 8 pieces.
    No idea what he meant, but don't bother with that kit, it's a waste of money. Most of what it replaces doesn't fit or you can buy the whole component with bushings installed for less money.
    Fwiw the bushings in question are just too big so there's enough shit to make it work if you hate yourself
    Feb 2012
    89/accord/lxi
    Quote Originally Posted by Jacques View Post
    I think what he was saying is that when you go to remove the bushings there is a metal sleeve/race/shim or whatever you want to call the part of the stock bushings that need to be removed. Most of the time theses are pressed in so they are quite difficult to get out. But once removed this kit should fit. Now I could be very wrong but that's what my take on thing's is and from experience this was something I've experienced.
    Sent from my SM-S918U1 using Tapatalk
  8. #33
    Jul 2015
    Bend, OR
    The money wasn't much, but if the LCA bushings are a no go not the end of the world. My factory bushings actually are still good.
    Looking, it seems the outer factory sleeves are shaped smaller at the ends, so now I see what he was saying. I'm not going to do anything with the rear LCA bushing now.
    It seems the other Prothane bushings will work. Thanks for the replies you two.Click image for larger version.
  9. #34
    Hell yeah, repping the STS class too. Lmao
    You can actually get adjustable rear arms for cheap, run these instead of those stupid eccentric bolts, there's no way the rear of the car is actually straight and true to the front.
    https://www.ebay.com/itm/111301093609
  10. #35
    Jul 2015
    Bend, OR
    Will they actually fit our 3rd gen cars? 1991 to 1997.
    Here is the link I have saved.
    https://meganracing.com/suspension/t...ms/mrs-ha-0170
  11. #36
    Jul 2015
    Bend, OR
    Do you have proof they will fit?
  12. #37
    Yup. https://www.3geez.com/forum/showthre...=1#post1226478
    4th gen cars have nearly identical suspension, save for the track width and front upper control arms. That and just the general size of things, like the bushings aren't interchangeable, but the arms themselves are, at least adjustable aftermarket ones
  13. #38
    Jul 2015
    Bend, OR
    Thank you! I was going to order those a while back, but then concerned they wouldn't fit.
    Now I need to figure what to do about the swing arm bushings. I have heard say, that factory ones are not available for years now.
    I already put on the Chedas rear upper arms.
    My rear suspension is the only thing that has not been rebuilt, and I'd like to get it done.
  14. #39
    For sway bars I do use the poly energy suspension ones... Those are also like dirt cheap and I'm pretty sure they're just a universal type. I think the one other bushings I used from the energy suspension kit was the strut rod bushings, but I don't think it's much of an upgrade, the front isn't very rigid under acceleration lol
    I'm using civic/Integra poly bushings in the trailing arms that were turned down... It was not easy. Mevotech adjustable rear uppers, prelude front uppers with the high camber mounts. I've also retrofit a bunch of civic/Integra parts like ball joints and tie rods.
    I really want to check out some different knuckles, maybe civic ones would be drop knuckles, but extended ball joints would also do that. I'm also curious what it'd do if it just took out some angle on the uca with an overall shorter knuckle. Then 4th gen front lcas are an inch longer so that'd be one way to get some more front camber without going nuts on the uppers
  15. #40
    Jul 2015
    Bend, OR
    Seems there is no easy solution to the trailing arm bushings. Maybe I'll need to have some custom ones made, or have them refilled with some type of polyurethane stuff, but that might be too stiff. Problem there is, those bushings need to have some flex to them as camber changes when the rear is working hard.
  16. #41
    The rear suspension on our car is where the magic is. Your right to tread lightly. The arm needs to turn a little that makes that bushing do alot of the work. The upper link is the only thing I have messed with in the rear. Even my sway bar bushings are stock in the rear.
  17. #42
    They make metal bushings for the civic/Integra that are kinda like a giant heim joint, those would probably be a lot more forgiving when turning them down to fit. They articulate more than our suspension would ever need though, but they would complete eliminate any fore/aft movement
    If you wanted to pour and mould a poly bushing that'd probably be quite easy.
    No problems with my bushings though, as long as you're not replacing it with a solid block of aluminum it'll be fine
  18. #43
    Jul 2015
    Bend, OR
    Would you have a link to that heim joint bushing? Not sure what you mean by turning then down. I wonder if the ID of those are even close.
    I found these: Link
  19. #44
    Oh yeah those bolt in... So you'd have to be pretty creative lol. As for the center hole it can just be sleeved
  20. #45
    Jul 2015
    Bend, OR
    I figured as much. I don't think I want to get that creative! Would make a nice joint if it could be done right.
    Would you happen to have an old factory bushing that you would sell, or have the EXACT dimensions of the trailing arm bushing?
  21. #46
    No they're in a steel sleeve and I cut the rubber out and reused the sleeve then just turned to fit. They weren't exact so I epoxied them in
  22. #47
    https://www.rockjock4x4.com/products...-johnny-joints
    I always like the Johnny joint design its a little more road friendly and I think its rebuild able.
  23. #48
    If the ID of those are big enough and they fit in the mount, then I bet they'd work pretty darn good
  24. #49
    Jul 2015
    Bend, OR
    Thanks I thought I saw some dimensions somewhere, but can't seem to find them.
  1. Energy Suspension or Prothane bushings
    By nswst8 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-25-2009, 11:04 PM
  2. Energy Suspention polly shift bushings 22 shiped
    By labeledsk8r in forum For Sale
    Last Post: 03-30-2009, 08:20 PM
  3. Energy Suspension Endlinks :)
    By mushroom_toy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-18-2008, 07:26 PM
  4. Energy Supension front sway bar bushings
    By Oldblueaccord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-26-2008, 08:47 PM
  5. energy suspention bushings
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-31-2002, 03:54 PM
