Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
Thread: CLUTCH How to NEEDED !
    Oct 2001
    87 Accord EX , 5spd , Manual
    thanx guys for the replies you rock !
    a small question > do i have to support the engine from beneath ?
    at the oil pan for example or the cross member ! ?
    MIKE
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    I supported the engine at the oil pan (Haynes manual says to do this). I think supporting the engine from underneath is important since you unbolt the rear motor mount. I used a jack stand with a block of wood on top to support the engine.
    Mike Clark
    Oct 2001
    ok thanx guys , i am finishin it up !
    MIKE
    AZmike's Avatar
    Tucson, Arizona
    I left the cross member in and put a few strips of wood in the gap between it and the oil pan to keep the engine from sagging very much. I undid the 14 mm bolts that attach the radius rod to the lower arm, but did not remove it. I left both axles in, but removed lower and tie rod ball joints, and the right dampener fork bolt.
    This was my first clutch job and I was working on dirt and it took 2 days 7-8 hours each.
    Mike
    Oct 2001
    do i have to remove the damper fork to get the axles out ?
    MIKE
    Columbus, OH
    I didn't remove the damper forks. I pulled the inboard CV joints apart leaving the inboard boot attached to the driveaxles. (Umm, not a good idea, but I didn't want to remove the damper forks. I've heard that the lower bolts always break.) Then I pulled the rest of the driveshaft through the fork. If you do this, be careful so you don't damage the inboard CV boots while pulling them through the damper forks. Also, the roller bearings on the spider fall off easily and THEY WILL ruin if they get dirt in them. I put sandwich bags over the exposed ends. You don't have to remove the passenger's side inboard CV joint, you DO have to remove the driver's side inboard CV joint to get the transmission both out and back in. I pryed the inboard CV joint away from the transmission using a small prybar.
    Thinking back on the job - it would have been A LOT easier to slide the driveshafts through the damper forks if I would have removed the steering knuckles. Removing the steering knuckles requires taking off the hub nuts. I highly recommend this.
    Thanks to Paul for the graphic!
    Mike Clark
    Oct 2001
    thanx site ! tah is what i wanted to know !
    MIKE
  8. #33
    Oct 2001
    sorry a small question ! i finall go a pic of where the speedo meter cable connects to the tranny !
    there are two hoses coming out of it ! shold i remove them too when getting the tranny out !
    here is pic that will be in the how to too !
    MIKE
  9. #34
    DX User Cloud892dr's Avatar
    Oct 2002
    89 Honda Accord 2DR LX
    Saint John NB, Canada
    yes it would be a good idea, I did, you might need something to catch the fluid that will come out of the hoses though, it will make a (pretty big mess)<------it happened to me.
    Speedometer cable can be a little tricky.
  10. #35
    Oct 2001
    ok guys thanks !
    MIKE
  11. #36
    Oct 2001
    i am finally finished ! just havd one question ! where do you guys put your jack stands while working under the car !
    here is a pic and some parts are marked and numbered could you tell me which numbers ( spots ) or suggest another place !
    thanx
    MIKE
  12. #37
    Columbus, OH
    I put 'em under the jacking points (not noted in your pic) that are behind the front wheel wells. That's pretty much where I always put my jackstands.
    Mike Clark
  13. #38
    Oct 2001
    some people have these places all rusted out ! where else can i put them ??
    MIKE
  14. #39
    Oct 2002
    Same here, i always put the jack stands right behind the front wheel well.
    Now if its rotted out there then i would use a spot where the jack stands don't stand a chance of sliding off the car, i would pick 1 & 2 on your picture they look like the better spots i had my jack slide off of 3 & 4 spots before, but that's my personal opinion.
    Mike. D
  15. #40
    Oct 2001
    are 1 & 2 strong enough ???
    MIKE
  16. #41
    AZmike's Avatar
    Tucson, Arizona
    MIKE
    Just remove the 10 mm bolt and pull the speed sensor. You won't have any leaking fluid or speedo cables clips to mess with. Just be sure to clean around it before you pull it out--you wouldn't want any grit falling down the hole.
    Mike
  17. #42
    Oct 2001
    do you mean to remove the whole holder ! someone said before that it's a bitch to put it back again !
    MIKE
  18. #43
    Columbus, OH
    I removed the 2 hoses and the speedometer cable, not the holder. I didn't have any fluid leak out, but I don't have power steering.
    Mike Clark
  19. #44
    Oct 2001
    i am really confused here ! is it better to remove the whole assembly or the hoses and cable ! ???
    MIKE
  20. #45
    Columbus, OH
    I'm no mechanic and I've only done 1 clutch job. So, I'd say do it the way 89LXi4dr says to do it.
    I'm a lightweight when it comes to auto repair!
    Mike Clark
  21. #46
    Oct 2001
    thanx site ! :super:
    MIKE
  22. #47
    Oct 2001
    here is how to link i posted in the technical section !
    here is the thread to type in any comments !
    https://www.3geez.com/showthread.php?s=&threadid=9149
    MIKE
  1. Mot Fail!! Big Cost. Advice And Or Offers Needed! Steering Rack Needed!
    By ESDEEZ in forum Classic Honda Community Chat
    Last Post: 08-12-2007, 08:19 PM
  2. Needed: Clutch Pedal Adjustment for Idiots
    By Cat3 in forum 3geez Accords
    Last Post: 03-27-2007, 10:06 PM
  3. what's needed for clutch replacement?
    Last Post: 09-25-2003, 01:26 PM
  4. New Clutch Needed???
    By Cacalac Jones in forum 3geez Accords
    Last Post: 06-13-2003, 11:56 PM
  5. clutch pics needed ?
    By ACCORD EX in forum Classic Honda Pics & Videos
    Last Post: 11-08-2002, 01:44 PM
