Results 1 to 12 of 12
Thread: Power Gains in Ignition?!?!?!?!?!?!?!?!
    LX User Nate2310's Avatar
    Oct 2002
    Exclamation Power Gains in Ignition?!?!?!?!?!?!?!?!
    This is the ignition stuff that I am thinking of getting:
    -msd ignition
    -ngk platinum plugs
    -nology spark plug wires
    -accel super stock coil
    -accel stock and rotor kit
    Does that sound pretty good?
    What are the gains that you think i'll be looking at?
    Ignition box
    89 Accord LX Coupe
    Vernon BC CANADA
    that should help out a bit
    im not sure on the gains but it will probably give you a few horses...
    your car should run better after that too...
    i wish i had money for all that.
    BEn
    Scorpion88LX's Avatar
    Oct 2002
    88lx,5speed
    winston-salem, North Carolina student at Oklahoma State
    Ingnition and power gains
    I have read many tech. manuals to learn mor about the way cars work and theory. I am taking this information from "Honda Builders Handbook Vol. 1". According to the author Joe Pettitt, the
    ingnition system doesn't make power for your car. " If you believe the claims made by just about any of the ignition component many-packagers, you'd almost think ignition systems 'make' power.
    Later he goes on to say that an upgrade in ingnition only helps the engine if the one already in the car is not adiquite for the car (which is unlikly for a honda because of the extreme enginering they put in), or the one currently in the car is not performing to it's ability due to many things like: wrong plug gap, short in plug wires, build up on plugs, distributer cap and rotor over used, ect...
    Not to say that adding new "better" parts wont help but they help to insure that there is always an adiquite spark and charge to deliver at the right time.
    So in conclusion the only way that you see a Hp gain after installing a new ignition component is becouse that component wasn't working properly or not adiquite for that car.
    By the way incase you were thinking that Joe Pettitt was just some joe blow guy writing on things that he has no experince in.
    He has writen several books ( Honda builders handbook vol. 1 and 2, High performance car stereo, How to install and use nitrous oxide, Sport compact car bolt ons, ect...). In his books he uses industry leaders for resorses and articles. He also writes has had articles for Sport Compact car and other mags.
    Just thought you should know and good luck.
    Oct 2002
    okay? well then why do people buy these things and state they feel gains in hp and acceleration and gas mpg????? jw
    Does this mean i'm going to get gains or not, and The main question was if that was some good stuff to get like brands and stuff. for the most bang for the buck
    Oct 2002
    88lx,5speed
    all the brands listed are good brands. although i used magnacore wires.
    people report power gains because the system they had may not have been working at its full ability. a new system can replace old and worn out parts giving an increase of Hp over the old worn out parts and greater mpg over the old parts.
    Ryan
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    diiitto
    accord HB ( metallic green)
    B.C Chilliwack
    I would go with all that except the ignition and save some seriuos $ - just my .02$
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
    1986 Honda Accord LXi hatchback
    Maryland
    the hp gains are all in the mind
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    it will run smoother and rev faster and it will seem faster... and if u ever put a cam in or a WEBER or headers then u will get increased power over stock ignition.
    Travis
    Oct 2002
    1987 Honda Acoord Lxi HB
    Knoxville,TN
    all that aftermarket ignition is probably overkill on a stock motor. Like was posted, the honda system is pretty good. yea, if your gonna build your motor with nos, turbo, supercharger etc... you would benifit from those componants but stock, probably a waste of money.
    10/Honda/Ridgeline
    NJ
    after market iginition wont kill ur motor, unless u advace ur timing like crazy then u will be thorwin up rods. U wont see much gain or even any, if ur existing stock igniton is working fine. THe only reason u would get an aftermarket ignition system is only when u have like lets say, a cam. or like a turbo or stuff like that for a precise and better combustion (more gas with better ignition). If u really want an ingnition system. Put it at the very end of ur mods list. cause u would be btter off spending the right money in the right place.
    LX User Experimental_Honda's Avatar
    Jul 2002
    94 accord lx, 88 sold
    ky
    i like the neuspeed wires my self......
  1. 86' LXi Ignition System Power Loss
    By firefighterwhite89 in forum EFI Tech
    Last Post: 01-03-2010, 11:27 PM
  2. power gains
    By alboy in forum Performance
    Last Post: 12-01-2004, 03:46 PM
  3. Replies: 3
    Last Post: 02-17-2004, 02:47 PM
  4. Exhaust gains??? Help..
    By Hash_man_Se_i in forum Performance
    Last Post: 08-23-2003, 02:28 PM
  5. Weber Gains?
    By 3rdGenFanatic in forum Performance
    Last Post: 11-10-2002, 08:15 PM
