Helo!
Tonite I have an 89 SEi automatic that is leaking tons of tranny fluid from the end cover while under load.
It is leaking from the 2 bolts facing the camera (that have fluid around the base of the bolt head)
The factory manual gives almost no info on these bolts other than calling it a "sealing bolt" and they have an o-ring and "seal washer" and hold in a spring and steel ball.
Also the factory illustration only shows 1 bolt... but there appear to be 3 in total (1 more in addition to the 2 which are leaking)
1) Can i remove the end cover without removing the trans from the car? (I could do this with my manual trans)
2) Can i just take these bolts out of the end cover while its still in the car and replace whatever washer/o-ring is apparently failing and still expect to put it right back together?
Thanks!
p.s. I hate automatics
