Trying to decide on how much I want to lower my car... please post pics of your lowered car, and describe your suspension setup, and any camber problems?,,, etc...
if your gonna go at all, you gotta go BIG.. this is with Lowboyz and Prelude control arms... lowered 3 inches i think??
Travis
i went 2.75 bro
https://www.3geez.com/showthread.php?t=29453&page=1
ractive coilovers, set at about 3" in the pic (very old)
Setup details:
1.3" drop front, 1.1" drop rear (moved perch to higher setting on rear dampers)
H&Rs with Konis 1/2.25 turns from soft front, 1/1.7 turns from soft rear
2.2 degrees caster; -0.5 camber front and rear; zero toe
Mike
yeah dude pretty much if oyu dont have rims and skinny tires i wouldnt reccomend lowring it, get tight wheels first!
Check out pictures of my car HERE
"drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
y not lower it without rims? i think a slammed accord with no rims looks way better than a 4x4 accord
Before lower job....
After Tokico shocks, and Eibach 1.5 inch lowering springs!!! Also the camber was about -2.5 degrees off all round. I put a camber kit, $200 on, and it's back to normal, which will save my tires alot!!! It is never worth it to lower car, if you don't plan on doing it right!!!!!
Here is mine with 1.75" drop with DZ coilovers and Koni's so far. Right now I'm at 2.25 and waiting for a lot of parts.
2.5" rear 2.25" front dropzone springs... tokico blue struts
Oh, Don't worry man, those are definately on the way!yeah dude pretty much if oyu dont have rims and skinny tires i wouldnt reccomend lowring it, get tight wheels first!
And bitesize, how do those Eibach springs ride? I have the Tokico blues, so I am thinking I don't want to go really low, and I like the look of that 1.5" drop. Especially cuz I will have 17's. And which Eibachs are they?
Here is my setup Koni's with H&R 1.5 Springs with 17" Racing Harts
The rear would be slightly higher without the weight of my system and battery back there so the front is a more accurate picture of the actual drop. I am going to switch over to Ground Controls this summer though so i can make changes as needed.
Mine are Eibach Sportline 1.5 inch drop springs, and they ride pretty stiff, good for cornering. I love them!
Hey dude how do you like the DROPZONE COILOVERS?What is good and what is bad about them?Originally Posted by lightbulblxi
I'm a mushroom cloud layin' mutha fu**er,muthafu**er--Samuel L. Jackson in Pulp Fiction http://www.cardomain.com/id/mattalica13
does anyone have a picture of a 3gee with a 1.5drop with 15inch wheels? I've seen a lot of the people who drop have 17inch rims so the fender gap is differnt.
heres a pic b/f i raised the ass-end
a old junky pic of me and mantis's cars
tokico springs tokico struts... now sus tech coil-overs in the back.
camber: some positve, no negative effects at all
I havent forgotten my roots
Before Drop:
After drop: Tokico Gas struts, and Eibach Sportline Springs, 2.5 inch drop.
it doesnt look as low as it really is.
Nothin' 2 Old Racing
sorry it took me so long to check back. the dropzones were easy to put on and they are easy to adjust. basically the only issue is the stiffness. they have a pretty stiff ride, so u cn fell every little bump, and u have to go slow over bigger bumps and railroad tracks. it is good to have the stiffer springs if u plan on auto cross and such.
-Brian
My Accord
Hmmm... I am now contemplating the drop I was going to go with, I may go lower now. But today I was looking at my car, and if I actually drop it 1.5" then it may be the perfect height, I think I could just get 4 fingers in between the fender and the tire, so, we will see.
I dont want it to ride like shit, and I don't want camber problems.
I should be getting my rims in the next month or two, so I have some time to decide... and suggestions?
Stick with eibach... They havent let me down yet! Great Handling with toxico's
I'm the original Gangsta of the dropzone coilovers, they aren't set at the lowest,, almost tho
here's with my 14" tires and rims:
and with my 17" teenagers:
