Results 1 to 19 of 19
Thread: Carb Issue
    Dec 2012
    Carb Issue
    Took the car for a drive, its wonderful now. Things that bothered me;
    Dizzy is turned all the way to the left, which is advanced if I'm not mistaken. That's the only way the car will run. When I come to a spot, she sputters bad, then stalls. The only way it won't stall is if I stay on the gas. Also, its sputtering a lot at idle, and I smell gas all the time.
    Anyway to help out with this? I can post pictures tomorrow when there's light out.
    Re: Carb Issue
    Check to make sure that your timing belt hasn't skipped a tooth. If it has, then you probably want to do a major timing belt service and replacement. Beyond that, it sounds like the carb needle valves might be pooping out. If they are, then you'll need to rebuild the carb or do a Weber swap if your smog laws allow that.
    Dec 2012
    Re: Carb Issue
    Ah shit. How would I know?
    Dec 2012
    Re: Carb Issue
    Scratch that: Timing belt is fine. Both crank and cam gears line up perfect. I need to know how to adjust this hell of a Carb.
    Re: Carb Issue
    That's the $64 trillion question, isn't it? Get your timing sorted first of all by setting it to factory spec. Then worry about the carb from there. If you're smelling gas all the time, then I would suspect your needle valves are faulty and the only way to fix that is with a complete overhaul. Before doing that, however, download the shop manual and start testing all the electric solenoids and vacuum pots that control the carb. Shop manual is here: 1989 USDM Honda Accord Factory Service Manual (I'm assuming you have an '89). Make sure all the vacuum devices hold vacuum and aren't hanging up on things. Follow the tests for each electric solenoid in the manual, starting on p. 11-3. Fix what's broken and hope it isn't your needle valves. If it is the needle valves, consider a Weber swap.
    Dec 2012
    Re: Carb Issue
    Big help Dr, thanks a bunch. As for TDC, I believe its set up properly. Two notches on the cam gear line up with the head while the "Up" inscription on the spokes is pointing north. Dizzy only goes in one way. Yet doing so fully advances my timing, which is how the car has always run, for whatver reason.
    Any specific tools I'd need to continue this menace?
    Possible to be done w/o a timing light? And is all of my info I need in the shop manual? Sorry, intermediate mechanic. Timing is one of my downfalls.
    Re: Carb Issue
    You absolutely have to have a timing light. I think you can borrow one from Autozone though. Spend some time in the manual. It's everything you could possibly need. It's one of the things that makes these cars so great.
    Dec 2012
    Re: Carb Issue
    How would I know when my cab went bad? During decelleration, it sputters like hell. If I come to a stop, she stalls. My timing is fine. When it comes to idling, she doesn't idle. Just stalls if I'm not on the gas.
    Re: Carb Issue
    So, it's a girl.
    Have you replaced the fuel filter?
    Does it start right back up with no trouble?
    Dec 2012
    Re: Carb Issue
    LOL. It is a girl. I haven't. And yes it starts right back up
    Re: Carb Issue
    Also check to make sure that the choke is opening completely.
    Dec 2012
    Re: Carb Issue
    One thing I have noticed under normal operating conditions, the choke is almost shut
    Nov 2006
    88 DX 5spd sedan 176Kmiles, 1 owner, stock. (Sold 10/18)
    Re: Carb Issue
    The choke opener attaches to a vacuum port on the carb. Lots of gas on the diapragm, it degrades and starts leaking. This vacuum circuit also feeds the high idle unloader, so it fails to step down too. Diagnose this area.
    Re: Carb Issue
    Yeah, fix that choke first and see where you are.
    Nov 2006
    Re: Carb Issue
    Running the car rich with the choke closed like that will cause all kinds of problems:
    * ruin the cat. converter, rapid carbon deposits, fouled plugs, fuel dilute the oil, rapid ring wear. 8-10 more things I can't think of off the top of my head. ie; Stop driving it until you get it fixed. At least bailing wire the choke open (it's almost summer)....
    Dec 2012
    Re: Carb Issue
    Headed outside to start toying with it. About 45 degrees over in CT. Seems like it's been doing a little better. Still sputtering at idle though. Should I start diagnosing my choke linkage? And is it suppose to be fully open all the time when the car is at operating temp?
    Re: Carb Issue
    Correct.
    LXi User SharkyX's Avatar
    Mar 2004
    1988 Accord LX-I
    Williamsburg, VA
    Re: Carb Issue
    The auto zones and advance stores out my way no longer lone out timing lights, I just went through this issue myself when replacmening my dizzy o ring. So not sure if this is a country wide thing.
    I ended up buying one for $30 at harbor freight a d tools that advance dial on it that worked (incase anyone needs a decent cheepo)
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    RIP: 1988 Accord LX-i
    My Car Domain Site http://www.cardomain.com/id/sharkyx
    Current 1988 LX
    https://www.3geez.com/forum/showthread.php?t=73596
    Re: Carb Issue
    Quote Originally Posted by SharkyX View Post
    Good to know. Thanks!
  1. carb idle issues caused by carb temp sensor discuss
    By lostforawhile in forum Carburetor Tech
    Last Post: 01-28-2017, 01:51 AM
  2. 87 accord hatch! carb issue... help?
    By Mercury in forum Carburetor Tech
    Last Post: 07-17-2010, 08:07 PM
  3. Replies: 19
    Last Post: 01-15-2007, 04:12 PM
  4. Hesitation + horrid mileage = carb issue?
    By gtivr4 in forum 2geez Accords
    Last Post: 10-10-2006, 03:11 PM
  5. carb issue; need help quick!
    By accordlxi2.0 in forum Carburetor Tech
    Last Post: 03-13-2004, 08:42 PM
