Results 1 to 24 of 24
Thread: [Sydney] Beast Build
    Feb 2013
    Honda Accord SJ-E 1980 Hatch Gen 1
    Sydney Australia
    Guys I decided to post up a bit of a diary about my restoration.
    This is the progress so far.
    New door locks
    5% Tints including front windshield strip
    Sony CD Player with 6" Speakers (New Wiring Yay)
    Remote Central Locking
    Alarm + Immobiliser
    Will try to take some more Interior pics if I have time tonight.
    DX User 1stgen!!!'s Avatar
    Jan 2011
    79 Accord sedan SJ5
    Brazil
    Re: [Sydney] Beast Build
    Nice job!
    The car is awesome
    You are looking for the left mirror and I am looking for the right mirror haha, mine is LHD
    Feb 2013
    Sydney Australia
    Yes, Ill contact the wreckers here and see what I can find. If you find anything let me know LOL.
    Thanks man. Its getting there..
    Next Up
    Either Restore the front seats as they are ripped on the trim.
    OR...
    Honda Prelude Seats install (Last Prelude)
    Then Paint Job.
    Then Wheels.
    I say restore the original seats, but I'm a stick in the mud that way. Car's looking good!
    Feb 2013
    Sydney Australia
    Stick with same blue interior? or change colour? Hmm...
    I do have DC2 Type R Recaros in red.. hmmm.....
    LXi User 79cord's Avatar
    Melb, Aust.
    Passenger side mirrors are a rarity, since they were a dealer fitted option. I have also found some aftermarket (drivers side) mirrors the same, though worse quality.
    Alternatively you might get a pair of the '75-8 mirrors (Civic or Accord) that can be used on either side. Lots are rusty though.
    I found early Integra seats fitted easily, & were available in blue... not so common now though.
    Looking good man! I would say a big no to those red Recaros. I don't think they'll look right in there at all unless you swap the whole interior to grey. Some period 80's Recaros would look pretty good in there, or the Prelude seats if you're looking for something to hold you in better.
    Jan 2013
    1978 honda accord
    sweet! very nice, indeed.
    Feb 2013
    Sydney Australia
    Quote Originally Posted by mopuddin View Post
    Going to see timer for quote soon. Might ask them to stiffen up the seats.
    Moar updates!
    Feb 2013
    Sydney Australia
    LOL, I better take some more pics then.
    I am searching for BMW headlights to do your mod.
    Is there a difference between E30 and E32/E34? The low beams on them look the same. I just dont know how you wire them up as the plug on the end looks different like HID style. The 3 pin regular plug would not be able to connect to that.
    They're similar, you gonna have to cut off the stock mounting tabs anyway. Get the stock plugs for them too if you can. Mine didn't came with them so I had to buy some plugs modded to fit. I believe they're extension cable for H11 bulbs: http://img.dxcdn.com/productimages/sku_147285_1.jpg
    I simply cut them in half, soldered the female part to the stock low beam wires and the male part into the BMW headlight connector itself.
    http://i1206.photobucket.com/albums/...x/DSC_1182.jpg see those yellow/brown wires? They connect to the H1 bulbs for the BMW projectors, I simply replaced them with the male part of the extension cord, basically replacing the stock BMW connectors with these. You can use whatever connector you want obviously but I choose these because they appear factory-like and water proof
    Feb 2013
    Sydney Australia
    Pic of wiring is tiny, but I think I get it.
    If I decide to go HID on these, then I wont need the bulbs I guess and the connectors arent as important as we can get the HID kit for the H11, then wire it into the H4 low beam harness and connect straight to the battery.
    Did you HAVE to cut away the low beam unit socket? Was there no way around that?
    Yeah I had to there is no way around that unless you get one of those male H4 socket thinggy and hack that instead so you don't have to cut off the stock low beam socket. I had all new wires anyway so its not a big deal. Good wiring + relays are highly recommended if you do this
    Feb 2013
    Sydney Australia
    How about the opening next to the battery.. you took quite a bit out of that hole too. Does the lens not sit flush if you don't enlarge the hole?
    Am i correct in assuming, a HID kit running 35w globes, would generate less heat and take less power than a 55w H4 globe?
    Technically yeah but a relay is still recommended so you won't overload the stock old wiring and switch. I've seen cases even with stock sealed beams where the connectors under the dash melted and causing a lot of problems.
    This is as far as they would go without enlarging the hole
    And you still gotta make the room for them on both sides
    Easiest way to do it would install the low beams on the inside where the stock high beam goes where you'll just enlarge the hole for them up front without having to hack the sides too.
    Depending on your battery size you might need to relocate the battery too. I already have mine on the crossmember (soon to be moved into the trunk) so it wasn't an issue for me.
    Feb 2013
    Sydney Australia
    Nice, think I will just have to hack it up a bit
    And get a sparky to install another relay thingo.
    I drove with those headlights for a few years. I can think of a lot of headlights I'd choose over them. The stock sealed beams in my 3g beat them hands down. It's your car, of course. Don't let me stop what you're trying to do.
    I guess the US version is worse than the EDM/the rest of the world version? idk mine is as bright and output is as good as my old H4 housings and beats the stock sealed beams hands down.
    They put out adequate light, but there is a severe cutoff to prevent blinding other drivers. They never lit any street signs, so it was always a guess where I should turn. When driving in rural or otherwise dark areas, it was impossible to see anything more than a little ways ahead. If you live in a well-lit metro area and never leave, they will probably be okay, but I wouldn't recommend them.
    The high beams are another matter altogether. They are amazingly bright and work wonderfully.
    LX User 1GCustomAccord's Avatar
    Jun 2008
    79´Accord,83´Lude,71´Nova coupe,83´Pontiac 6000,69 Mustang coupe,and many more rusted crap...
    PY
    I've used 95/100W sealed beams in my Accord with all 8 filaments on in high beam in stock wiring/switch for years without any issue, the conectors worked flawless, but a couple relays would have been in order. The lighting was just amazing, high beam turned night in day (780 Watts).
    So many reasons why
    I won't be sending postcards
    From Paraguay
    I wouldn't risk it on old cars like this. I had a pair of low beam H4 replaced on this guys 1g and it heated up the switch after a while. Relays are cheaper and easier than trying to replace melted switch and wiring! Not to mention the added brightness from them running directly from the battery
    The old 1g headlight switches liked to heat up even in the stock configuration. I wouldn't do anything without wiring in a relay in those.
    Feb 2013
    Sydney Australia
    I noticed that the headlight switch does get a bit warm when the headlights are on LOL
  1. [Sydney] New Guy
    By SjNoob in forum Newbie Introductions
    Last Post: 03-01-2013, 01:58 AM
  2. check out muh beast
    Last Post: 09-28-2005, 07:55 PM
  3. The beast is BACK!
    By Dibbs in forum Classic Honda Community Chat
    Last Post: 04-21-2004, 08:49 AM
  4. how about making my car a beast...
    By babyblue89 in forum General Engine Swaps
    Last Post: 03-23-2004, 12:28 AM
  5. My Car Is A Beast!!!
    By sccrsteve5 in forum Classic Honda Community Chat
    Last Post: 02-19-2004, 06:48 PM
