what aftermarket parts (pistons, valves, cams, cam gears, etc.) will work on the b20a that are from different engines?
B16/17/18 pistons, H23A rods, not confirmed but Justanothermike said F22 cam gears should work, and B20A5 cams (88-91 Prelude) cams look identical for fittiment, and the B20A5 flywheel.
www.b20accord.com
timing on the gear is slightly different and the belt doesn't sit in the middle of the gear but it works.
just use an adjustable camgear then
I need these parts!
thats wut i'm talking about. the timing on the gears is slightly different. if u have it at 0 degrees, i believe that it will be slightly advanced. so you can't rely on the timing marks on a F22 adjustable gear. they won't be the correct readings.
