Anyone know how to remove the glass from a 1st gen Accord mirror? I need to take it out to push out a couple of small dents from this:
Cheers, Glenn.
Cheers, Glenn.
Congratulations.
I think you might have to cut the hard rubber retaining trim & 'glue' the glass in again afterwards with non-acetic silicone or polyurethane sealant/adhesive.
I broke the glass on one trying to remove it & had to cut a new piece from a cheap mirror. Paint inside too given how many rust from the inside-out.
Thanks 79cord, yeah I broke the glass in both mirrors I have to get them out, lucky I did because they had surface rust inside which I cleaned up and painted.
Cheers, Glenn.
Cutting a cheap mirror roughly to size with glass-cutter & sanding into shape worked fine, though took two tries and some are awfully thin glass.
i think doorman has the glass
