Results 1 to 9 of 9
Thread: 88 honda accord smoking problems
    Feb 2012
    88/honda/accord lxi
    Reidsville, North Carolina
    So i just fixed my oil leaks and i thought that was the cause of the smoking coming from under the hood but now i found out that power steering problems can cause smoking as well. If my power steering is leaking out would the pump be the first logical thing to change. Since i got the car it has always been hard to keep fluid in the car. Do know if this helps anyone but when the car is running and the fluid gets low the fluid bubbles in the power steering bottle and alot of times im guessing the pressure pops the cap off its always laying behind the bottle. What you guys think i should do ??
    Re: 88 honda accord smoking problems
    Sounds like the fluid is aeriating, maybe wrong fluid or clogged filter in the reservior.
    Feb 2011
    89 Dx, 89 LXi
    New West
    Check the hose that comes up along the upper rad cradle past the dipstick. One little pinhole in there can cause fluid to hit the exhaust manifold occasionally.
    Nov 2006
    88 DX 5spd sedan 176Kmiles, 1 owner, stock. (Sold 10/18)
    Yeah, this happens when the fluid is contaminated or the wrong fluid is used (...is it red?) Honda fluid should be straw colored. Purge the power steering fluid and fill with Honda fluid only. Do it ASAP, and hope it hasn't already caused seals to leak.
    The P/S high pressure line goes over the exhaust manifold and is known to get old and leak. When it leaks, it drips P/S fluid on the exhaust manifold. P/S fluid is flammable, so if the line is leaking, change it ASAP as it can cause an engine fire.
    Mar 2003
    2004 Acura TL
    Arkansas
    About 12 years ago the shop I worked at told the customer that his pressure hose was leaking, he chose not to fix it and it burned his house down.
    Other common leaks under the hood are the pump shaft seals.
    Quote Originally Posted by Jafir View Post
    *Gulp*
    this is true. My 88dx caught fire after pulling into honda to get the hose. my uncle ran out and got the extinguisher. im glad now that i have my b series swap the line goes thru the other side of the car
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    I had leaks in both; the hose was slowly seeping. If you have the old style hose - looks like covered in a cloth type of thing - try bending it slightly and you may see fluid in between the cloth joints...
  1. 88 Honda Accord LXI transmission problems
    By SladeHonda in forum 3geez Accords
    Last Post: 03-07-2012, 08:03 PM
  2. 88 Honda Accord LXI idle problems
    Last Post: 02-23-2012, 12:49 PM
  3. 86 Honda Accord Dx Having Engine Problems.
    By stillhoopin22 in forum Carburetor Tech
    Last Post: 03-29-2006, 01:11 AM
  4. HELP 87 Honda Accord LX Problems
    By azazel_18_2 in forum Carburetor Tech
    Last Post: 03-10-2006, 07:38 AM
  5. 1987 Honda Accord problems
    By chello in forum 3geez Accords
    Last Post: 06-29-2005, 04:07 PM
