Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 113
Thread: Ap1 s2000 digital guage cluster.
  1. #51
    Re: Ap1 s2000 digital guage cluster.
    you are going to have to do it wire by wire, solder and heat shrink. you probably need a temp sensor from a late model civic too, they should be the same as other hondas, the ohm range on this one is really strange, i tried to find one before. the threads on the later honda gauge sender are also bigger then the accord
  2. #52
    probably the most important plug on there too. can you cut that whole chunk out of the cluster to use as a plug? dunno if its possible to reliably solder to that flexible plasticy terminal board stuff though (dunno what it's called lol)
  3. #53
    is there a pigtail that it has to attach to? trying to figure this out, just cut off the plug end
  4. #54
    I'm already running one from a b20b lol.
    That's exactly what I was thinking, soldering to those points seems very difficult.
    Don't want to cut the harness at all, I may cut out the cluster piece and use a more solid plug connectors.
  5. #55
    you can always save the plug and solder it back in if needed, i believe those plugs plug in at the big three connector junction at the dash anyway, I think that entire part of the harness unplugs, you could always get another
  6. #56
    Alright going all mad scientist on this lol.
  7. #57
    Looking good man. This is going to be awesome!
  8. #58
    that should work well
  9. #59
    Nice work (Y)
    good idea (Y)
  11. #61
    Very nice work
    I've got everything hooked up except the rpms (for some reason they do not work), and the vss. Definitely a better way would be to pull the harness from the junk yard, and re-pin the whole thing. I just wasn't aware it was an individual unit.
  13. #63
    you dont have it hooked up to a electric vss
    Idk, I thought the fuel ratio was variable to the speed you were moving. So I need to know the rpms for speed to work, but the a7 plug does not send a signal that makes the guage move at all.
  15. #65
    i'll look it up later
  16. #66
    Not to my knowledge. Slightly variable according to vacuum, manifold pressure or throttle angle, but not speed. In general, you'll be shooting for 14.7/1 A/F mix in most all conditions other than hard acceleration.
    Not sure if that helps.
  17. #67
    I think I miss understood your question when I read it the first time (little drunk lol). I have not hooked up the vss yet, cause I want to make sure everything else works as this is my daily driver. Vss will be simple, the wires to the ecu and cruise are already there, just need to wire up the rest.
  18. #68
    That's what I wanted to know. No possible way replacing sender with a integra civic one
    That is what I'm going to use, the vss sensor is from a newer Integra.
  20. #70
    Sweet . Lmk
    does it work yet?!?1
  22. #72
    No I have not wired up the VSS yet. I've been busy at work, really want it going to!
  23. #73
    come on slacker lol
    come on slacker lol
    Just sayin....
  25. #75
    I was waiting for you to hit teh vtaks :'(
  1. DIGITAL Cluster AND Climate
    By L3G10N in forum Wanted
    Last Post: 02-20-2013, 12:35 AM
  2. How much does a digital cluster worth these days?
    By Hazwan in forum Classic Honda Community Chat
    Last Post: 12-25-2012, 12:08 PM
  3. guage cluster
    By import racer in forum Interior & Exterior Care
    Last Post: 06-27-2007, 07:57 AM
  4. REQUESTING PHOTO of JDM digital cluster
    By DarknessRS in forum Classic Honda Pics & Videos
    Last Post: 04-07-2003, 12:16 AM
  5. Guage Cluster
    By Mike89Accordcom in forum Classic Honda Community Chat
    Last Post: 09-28-2002, 11:14 AM
