Results 1 to 12 of 12
Thread: Gauges
    Jul 2009
    Somerville, Alabama
    Gauges
ID:	5037Click image for larger version.
ID:	5038Click image for larger version.
    I Love having gauge readouts. Still gotta get an attachment for my Fuel PSI gauge but it's 1/8" Male and the Fuel Test Bolt on the Fuel Filter is M6 x 1.0. I haven't found any adapters to adapt that. Anyone got any ideas? I'm sure i'm not the only one who has had this problem.
    And my Vacuum Gauge connected to my Intake seems to prove it's worth every time i ever get a vacuum leak.
    Next on the list of gauges to get is:
    Oil PSI (Glowshift Red Digi)
    Coolant Temperature (Glowshift Blue Digi)
    I've got two HOYT Ampere gauges.
    Would you just hook it up to your Alternator? Would one connected to the battery be in anyway useful?
    Shaggy
    FF II/ETC I
    Re: Gauges
    get rid of the ammeter, use a volt meter, ammeters are a fire waiting to happen, they have burned up a lot of cars, since all the current from the alternator has to go through them, also get an electronic fuel pressure gauge, you dont want fuel under pressure coming directly into the car, or get a gauge isolater, it keeps the fuel under the hood, and still lets you use a mechanical gauge, you never want fuel past the firewall. I know Honda puts the fuel lines in the car, but there are no actual connections inside of the passenger compartment, only a solid steel line, which isn't likely to leak, if you had a connection fail on the gauge or line, it would be spraying fuel all over the car and knowing all the electrical behind the dash, it would be really bad really fast
    Re: Gauges
    I believe MSC Industrial is the place to get very hard to find thread adapters. I used their adapter to convert the oil pressure sender threads (1/8" BSP) to work with a standard oil pressure gauge (1/8" NPT). Thanks to Lost for doing that research.
    Re: Gauges
    he doesnt need to have a fuel line coming into the car at all, thats a disaster waiting to happen, electric gauge or gauge isolator under the hood, I'll probably even run one for oil pressure eventually, having an oil line break in the car was bad enough, a fuel line doing the same thing could kill you
    Jul 2009
    Somerville, Alabama
    Re: Gauges
    It is an electronic fuel gauge. Has a unit that adapts somewhere in the fuel line, and wires carry back to the gauge from the sender itself.
    This thing.
    Tinted 7 Color 100 PSI Fuel Pressure Gauge - GlowShift Gauges
    www.glowshiftdirect.com › ... › Tinted 7 Color Gauge Series
    Sent from my GT-P3113 using Tapatalk 2
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    Re: Gauges
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    Re: Gauges
    I already have these.
    those were free. These are next.
    I've got this gauge if anyone is interested.
    Shaggy
    FF II/ETC I
    Feb 2011
    89 Dx, 89 LXi
    New West
    Re: Gauges
    If you really want an ammeter in your car, look for one that uses a shunt. That way you need not run full current to the meter and back. They ain't terribly cheap though.
    Jul 2009
    Somerville, Alabama
    Re: Gauges
    I'm pretty sure this one uses a shunt.
    Shaggy
    FF II/ETC I
    Re: Gauges
    do what I did get the SDC heads up voltage monitor, replaces the idiot light for the alternator and a voltage gauge, all at once. it's pretty intuitive, one single led three colors, flashes for over voltage and under voltage, instantly tells you if the alternator stops working. if everything is normal the LED stays green then dims to not be a distraction, if anything changes it comes back up to full brightness and gives you the status by color and flashing. they were originally designed for motorcycles, so the micro processor is tiny, I have a thread somewhere, I went to a lot of trouble to get rid of my alternator idiot light, and install a clear battery icon in the cluster so the LED could be put behind it
    https://www.3geez.com/forum/accord-au...e-monitor.html
    cygnus x-1's Avatar
    Chicago area
    Re: Gauges
    For the fuel pressure sensor you need one of these:
    Honda Fuel Pressure Gauge Adapter Banjo Bolt 1 8" NPT | eBay
    C|
    DX User Bud_1080's Avatar
    Jul 2013
    89 accord racer
    Canada
    Re: Gauges
    You could also drill and tap your existing bango bolt for 1/8". Either the one on the fuel filter or right on the fuel rail.
  1. gauges??
    By od2681 in forum Performance
    Last Post: 06-02-2004, 08:27 AM
  2. Gauges for 86?
    By Rendon LX-i in forum Interior & Exterior Care
    Last Post: 05-01-2004, 01:20 PM
  3. Which Aux Gauges Should I Get?
    By xbi0s in forum Interior & Exterior Care
    Last Post: 02-09-2003, 12:24 AM
  4. gauges
    By nanaimo_honda_accord in forum Interior & Exterior Care
    Last Post: 02-05-2003, 03:34 PM
