Results 1 to 15 of 15
Thread: griffs68's 1988 LX Build
    Mar 2013
    1988 accord lx 1968 ford mustang 2001 chevy 1500 4x4
    Bakersfield, CA
    So i bought a 88 lx from craigslist to spare me the fuel costs of daily driving a lifted 4x4.
    Got it not running for 400$( okay running but froze waterpump)
    So far I have done: New wp, T-belt crank seal cam seal tensioner, plugs wires cap & rotor, front calipers and brakelines. 4 tires and an oil change.
    Plans include to install drivers door handle and regulator. all new front end parts.
    Got a set of ST drop springs from a member and have the fronts on new KYB's waiting for some more $$ to install the rears on new KYB's then swap them in.
    New door handle from Honda
    Re: griffs68's 1988 LX Build
    Nice! Do you have an infrared scanner mounted in the key hole or are you just missing the lock cylinder? LOL
    Mar 2013
    Bakersfield, CA
    just missing the saftey cover the lock cylinder is there and works...
    looks like a nice daily
    Nice find!
    Mar 2013
    Bakersfield, CA
    Cool Re: griffs68's 1988 LX Build
    So I took this in to get it's cali SMOG, sad to say it failed nox by over 300ppm. working on this problem
    But I did have some other stuff I needed to get on the car so after work today I installed both new fuel filters and the new pcv vale( still had the old style plastic one). While replacing the fuel filters I took it upon myself to replace the fuel lines under the car, while doing this I found that the rear fold down key thing is broke. Next step for today was to install the prothane front sway bar links. Need to do the bar to frame mounts, anyone know the prothane number?
    No pictures today but Wednesday I will be doing the lowering coils on the front and rear with new struts. Along with new outer tie rod ends and a power steering rack.
    High NOx is almost always an EGR problem. Are you getting a check engine light? You didn't go gross polluter, did you?
    We need to be more activist on this board about keeping people out of the weeds when it comes to California smog checks. They've changed it all around again since introducing the Star smog checks. From what I've read, if you fail too many smogs, California makes you do the Star smog, which is like the uber-Nazi smog check. You don't want smog failures being reported to the state. Pre-tests are not reported. If the shop tells you they don't do pre-tests, then leave and go somewhere that does.
    We need to round up all the minty 3geez in Cali, and have them sent to Texas where they are rewarded for lasting so long!
    redneck's Avatar
    May 2012
    08 tsx,89 sei coupe, 88 lxi sedan
    lexington, sc
    im so glad i dont have to deal with that smog crap. how many miles ya got on that?
    Mar 2013
    Bakersfield, CA
    Well it doesnt have a CEL on, only failed GP the first smog test, it was non-oped so it required a star test to start. Failed 350ppm on the nox at 15mph passed on the 25mph by 7ppm. Guess this means something in the black box is not turning the EGR on. Has 184500 miles on it...
    Or the egr and port may need yo be cleaned.
    Mar 2013
    Bakersfield, CA
    Hate acting like a prick.... BUT FUDGE I am a master tech the first think i did was manually activate the egr... stalled out even at 1500rpm the egr port is clean...just not being activated... will post more on what I find on wednesday, plan is to figure out the egr, install new power steering rack and drop it down some
    Oh, right. You have a carb, so no CEL. Um...good luck with that one. LOL
    There are some EGR troubleshooting tests in the manual starting on p. 11-71. Keep us posted on what you learn. I'd be happy to hear more about what they do at a Star test. I'm pretty familiar with the normal test, but the Star test is a new bureaucratic abuse I haven't yet had the pleasure of enduring.
    I love this state. You can put pink slime in the meat and BVO in soft drinks and feed it to people. You can spray the most amazing poisons over the food crops. But if your car is slightly over its smog limits, you have to junk it and ride your bike. It's time for some serious house-cleaning in Sacramento.
    Mar 2013
    Bakersfield, CA
    So tonight I put the new front & rear struts with drop coils and replace the radius arm bushings. O and installed me new power window switch
    Will have new pictures up tomorrow..
    Then the fun stuff starts checking EGR bull shit!!
    So if you non-op the car, then they want a Star inspection when you go to put it back on the road?
  1. Hash_man_se_i's 1988 EX-i sedan build
    By Hash_man_Se_i in forum Project Central
    Last Post: 12-11-2019, 05:44 PM
  2. Burn1nRubb3r's 1988 DX Coupe DD Build
    By Burn1nRubb3r in forum Project Central
    Last Post: 05-16-2012, 10:38 AM
  3. Help with my Build
    By 2drSE-i in forum Restoration & Custom Fabrication
    Last Post: 11-01-2007, 09:44 AM
  4. please help me build a box
    By buttaz1 in forum Interior & Exterior Care
    Last Post: 04-20-2007, 09:01 PM
  5. re-build
    By wprocomp in forum Classic Honda Community Chat
    Last Post: 05-23-2003, 02:46 PM
