So after this summer, I hope to have enough cash to do a bit of building on my stock A20a1. I need a new clutch, so I figured I might as well rebuild the block and such with gaskets and seals, get the head and block milled and a p&p job too. Headers, (hopefully) and a 2.25" exhaust out the back, high-flow cat. and muffler. Maybe a flywheel lightening job, and a cam grind (justanothermike's?) and cam gears. I also wanted to get either a dual carb setup...or a single Weber...and that is where I am not so sure on where to go.
I hope to spend under $5000 on the whole build, but the carb setup is what I expect to take the most money. Which way should I go, dual Webers or a single Weber on the stock manifold?
Any other comments on my plans, please tell me!
