Results 1 to 11 of 11
Thread: connecting rods
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    connecting rods
    So I found these rods and wanted to see what you guys think about the. For the money there not bad and from what info I've been able to find everyone seem to be happy with them. I think about get s sent they would be a bit over kill for my build but I've gonna do it I'm gonna do it once.
    cxracing.com: Civic Integra B18 B18A H-Beam Connecting Rods + Bolts 5.394" Rod Length
    Feb 2012
    89/accord/lxi
    Re: connecting rods
    So I was just offered a ls block that has been sitting and may have bad bearings. My question is are the LS rods and pistons any stronger than stock a 20 rods and pistons.
    Re: connecting rods
    idk bout the rods in the link but I do know that ull have to bore the a series motor out to use the b series rods so urr better off buying nice quality rods instead of using old oem ones.
    Feb 2012
    89/accord/lxi
    Re: connecting rods
    That's out I was thinking. I would have the shot pinged, heat treated and all that good stuff. It's just hard to find piston and rod combo that's not crazy expense. I'm not trying to make a insane amount HP 250-300 would be fine due to the fact I would like to dd the car. What do u have in mind
    SEi User
    Jan 2004
    Re: connecting rods
    Std rods balanced with lighter forged pistons and lighter wrist pins are a very good combo as they are very light I've had no issues with stock A20 rods at 200bhp and 8000k rpm use. But depends what your goals are really with that much power you'll definately need forged pistons or the cast ones won't last very long, stock rods maybe fine for 250 but if you push it to 300 that could be there weak point but you really want lighter rods if possible I think BC do a sportsman light version which is 440grams 100 grams lighter than most but still not as light as oem but they'll cost you $400 for a set then add pistons on top 83mm bore size your quickly heading towards $1000 in parts.
    Re: connecting rods
    ive seen a few people use the b18 golden eagle rods. you will need to get over size pistons because the a20 bore is 82.7mm
    Feb 2012
    89/accord/lxi
    Re: connecting rods
    So I've been lookin to the eagle rods and come to find out cxracing(ones j posted), scat and eagle are made by the same place so aside from a name the are close to the same. from there Companys many shave them down to make them lighter and stamp there name s on it. The cxraxing rods are around 580 grams from what I found so out of any the of the BC one there right on par with any other forged connecting rod
    LX User knifemind's Avatar
    Mar 2008
    88 dx & 85 Lude
    Montana
    Re: connecting rods
    That is very interesting. I thought surely they were just cheap lookalikes.
    Feb 2012
    89/accord/lxi
    Re: connecting rods
    Quote Originally Posted by knifemind View Post
    you see this alot with Honda parts I cheaper to find the place that makes and have them cut middle man got of the way so you not paying for a name.
    Re: connecting rods
    My stock rods (b18b1) revving to 9.5 an are strong. K ill leave now
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    Re: connecting rods
    manley.
  1. replacing connecting rods & pistons
    By 88accordSF in forum 3geez Accords
    Last Post: 06-20-2007, 07:38 PM
  2. Connecting rod play?
    By BITESIZE in forum EFI Tech
    Last Post: 03-28-2006, 09:58 AM
  3. Shot peening connecting rods & why..
    By 88Accord-DX in forum Performance
    Last Post: 01-29-2006, 09:52 AM
  4. Replies: 31
    Last Post: 12-07-2003, 07:53 PM
  5. does any body make connecting rods for our 3geez
    By accordmanracing in forum Performance
    Last Post: 04-16-2003, 03:21 PM
