I got a motor that runs great.
When I start it up it is fine and once it warms up the oil light starts blinking then comes on at idle but at about 3k rpm it blinks again.
if i look into the valve cover it is still spitting oil everywhere and I am running 20w/50
I read somewhere to check the bottom end bearings so i did
I replaced the main bearings and the connecting rods bearings looked great ( I think those where changed before i got the motor recently)
I put a oil sending unit off of my old motor on it to make sure it wasnt that bc that motor never had oil issues just a bad crank on that one.
that had no effect.
I have checked the return lines and put a new filter on.
none of this has changed anything.
not really sure what to do next.
When the light comes on the motor still sounds totally fine.
not really sure what to do?
any ideas? please help.
