Results 1 to 9 of 9
Thread: transmission
    Oct 2002
    1986 Honda Accord LX
    Georgia, USA
    Question transmission
    im having a problem with my 86 accord, i just recently installed a new clutch kit, not a high performance, but stock replacement, and i got everything put back together, started the engine and now it has a "pecking" noise...and i dont have any power steering now, if anyone could possibly help me, please do
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Check your PS pump belt tension and PSF level.
    Does the noise happen with the clutch engaged, disengaged, or always? Were you careful to keep the flywheel, clutch disk and pressure plate clean during the whole job? Oil or grease on the friction surfaces can cause 'chatter' when the disk slips and grabs.
    Mike
    Oct 2002
    Georgia, USA
    the noise happens at all times, idle, in neutral, clutch engaged and disengaged, going down the road, yes i was very clean with my work....but everything runs just fine....no drag in the engine like something is rubbing against something else....but i did go back out there and there are 2 lines that go to the transmission, i traced them to the power steering canister, do u think there is a possible way it needs the fluid filled back up?...cuz i have no power steering whatsoever right now
    shepherd79's Avatar
    Falling Waters, WV USA
    yes, putt those lines back where they were. they control your power steering.
    fill up with power steering fluid, don't forget to use HONDA POWER STERRING fluid.
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    i know hondas fluids our the best for our cars, im just curious as to why it is better then regular PS fluid.
    ACT Stage 1, Short Ram Intake & 2.25 Dynomax custom catback w/4inch carbon fiber tip. Thats it for now.
    Putting the paint back on after
    SOMEONE STOLE MY PAINT!!!!!
    shepherd79's Avatar
    noone knows, it is a mistery.
    10/Honda/Ridgeline
    NJ
    yep, no one knows it but its soo recomened that u use HONDA specified PS fluid to have the whole PS system running good. I gotta get some too. what can i get? gunk shit or anything else?
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I'm not too sure how Honda PSF is different, but I've heard that anything else can eat your seals, or at least wear them out a lot faster.
    Mike
    Oct 2002
    Georgia, USA
    thanks for all the help ya'll...i did fill back up with PS fluid...no change in the noise...im gonna look at a few more things..and adjust the valves today to see if that helps..the more and more i listen to it..sounds like the valves
  1. lxi transmission - help!!
    By honda in forum EFI Tech
    Last Post: 02-02-2007, 06:39 PM
  2. Is it the transmission?
    By slowsixtyseven in forum 3geez Accords
    Last Post: 03-19-2005, 08:04 PM
  3. Transmission
    By Rell in forum 3geez Accords
    Last Post: 05-25-2003, 04:29 AM
  4. transmission
    By juiquan in forum General Engine Swaps
    Last Post: 12-05-2002, 07:05 PM
  5. new transmission
    By 2old_honda in forum 3geez Accords
    Last Post: 11-26-2002, 06:00 PM
