Results 1 to 3 of 3
Thread: stupid clutch cables and their need to be located properly
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    After replacing my pedal assembly for a broken clutch bracket, I've been fighting with a stiff clutch pedal that never wants to act right. Sometimes it was SUPER stiff and other times it wasn't. At first the clutch would engage when the pedal was almost completely extended, then after a while I could hardly get the clutch to disengage at all. And it was always sticky when I pressed the pedal to the floor. It would hesitate to come off the floor and made shifting a bit difficult at times.
    Today I could hardly shift so I was going to adjust the clutch. As I was doing so I thought that my problem might be due to how the cable is routed in the engine bay. I moved it to the other side of my CAI and now the clutch is light as a feather with no sticky problems and it shifts perfectly.
    TL;DR - route your clutch cable as direct as possible with as few bends as possible and your shifting life will be worry free
    Nothin' 2 Old Racing
    Re: stupid clutch cables and their need to be located properly
    Great it cleared up , good advice
    Glad you got it fixed.
  1. I need help replacing Battery cables
    By 314lxiSleeper in forum EFI Tech
    Last Post: 12-15-2008, 10:48 PM
  2. grounding cables
    By pervasto in forum Performance
    Last Post: 07-02-2004, 11:08 AM
  3. where should I run my cables??
    By AD9SloAccrd in forum Interior & Exterior Care
    Last Post: 05-09-2003, 06:38 PM
  4. Stupid Clutch Question
    By 1989se-i in forum 3geez Accords
    Last Post: 09-12-2002, 06:52 PM
  5. Cables
    By sanjay in forum Interior & Exterior Care
    Last Post: 09-04-2002, 01:57 AM
