Strange I posted this yesterday here and it vanished?
Wondering what the offset is for our 1Gs, I found a set of wheels that is -38 offset 14 x 7 to fit.
+38 I hope? If so then it should fit just fine with stock height. I have both 14x6 and 15x6.5 and they clear fenders fine after rolling the lips.
If its a negative offset then![]()
I'm running 15x6 w/ 40mm offset. But the 4x100 conversion does seem to change the offset from the standard a bit. I would think a 36 offset on a 14x7 would be fine, depending on tire size.
My bad it is 15 x 7 and positive 38
Should be fine. Where did you find 15x7 that fit 4x120? PICS!!!![]()
Ive found two sets of non-stock wheels in 4x120...and i do A LOT of searching...lets see these wheels??
