I have an 85 accord and I am beginning to experience some potentially large issues. Recently, the car has been idling rough and bogging down at stops (automatic transmission), sometimes to the point of dying out. It has also been having issues getting up to speed(underpowered).
The car burns a lot of oil, so my guess is that the previous owner had it under the recommended level for some time. After getting the oil where it should be, the car runs a little smoother, but still not 100%. I've tried spraying carb cleaner everywhere to test for vacuum leaks, but I haven't noticed anything. I have also put some fuel system cleaner into the tank in hopes that it cleans anything that may be inhibiting the engine. Car is bone stock with 80k miles.
What could the problem be? What can I do to further diagnose the problem? Thanks
EDIT:
I read that I should be able to figure out whether the problem is the brake booster or not by plugging 'it' with a golf tee, though, it doesn't go into much detail as to what I'm plugging. Since the engine provides vacuum for the brake booster, that would imply I should be plugging the port on the engine. Since there will be no vacuum for the booster, braking will become an annoying task. Is that right? Is this a safe way to diagnose the problem?
