Results 1 to 13 of 13
Thread: loud squeek and smoke under hood
    LXi User 89lxi95zx7's Avatar
    89 lxi 95 750 ninja
    Pittsburgh,PA
    Lightbulb loud squeek and smoke under hood
    ON the way to work this morning i was doing about 75 mph,i heard a loud squeel from under hood.i went away afer a few seconds,pulled up to light and smoke wads coming out from under hood.got to work,looked under hood,nothing out of place.so
    kevin
    Banned Neuspeed007's Avatar
    Oct 2002
    1995 Civic Ex
    BOISE IDAHO
    you might have had a hose snap, check all your hoses, or metal might have grinded on something, just check all the small stuff
    89 lxi 95 750 ninja
    Pittsburgh,PA
    i'm done w/ work in 20 mins., my 1st thought was a belt.
    THANX NEUSPEED
    kevin
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    check if the water pump seized... if it did then don't go driving
    Oct 2001
    87 Accord EX , 5spd , Manual
    how was the tempreture when that happened !
    MIKE
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Can't an alternator going bad do all those things?
    Mike
    89 Accord LX Coupe
    Vernon BC CANADA
    id check the pump or the alternator....
    i had my water pump seize on me in my old accord....so i ripped the belt off and drove it straight home...just dont let the car overheat if it is that....then your looking for more trouble.
    BEn
    Oct 2001
    what is a siezed water pump !
    and what is the symptoms of water pump goin bad ? i know the car is overheating but it could do that for a lot of reasons !
    MIKE
    87accordlx's Avatar
    Sep 2001
    1987 honda accord lx
    Ontario
    BEn
    isn't it the timing belt that drives our water pump? if so you aren't gonna move anywhere without a timing belt
    -Scott
    3geez member since Sept. 27, 2001
    "its a shame that our society as glorified the thug life. It just churns out fearless idiots with guns " - Pimp86LX
    SEi User
    81 HB LX, 84 HB S, 89 LX-i Coupe
    Indianapolis, IN
    The timing belt needs to "worK" for any belts/pulleys to work. However, he could have a fried V belt and the timing belt still work. The water pump belt also turns the alternator pulley. His timing belt is fine obviously, but there could be a damaged exterior belt...
    89 Accord LX Coupe
    Vernon BC CANADA
    a water pump that is seized is when the bearings inside have got ruined by water entering them and then when the car has sat for a bit the rust seizes the bearing and your pump will not turn...
    theres a hole underneath the water pump on the pump itself.Its a "weeping hole" ...there a seals on the pump shaft that seal the water from the bearings and when the seals go bad and passes them the water will drip out the hole and down underneath the pump or hit the belt and splatter under the hood..
    the pumps also wear out from use....IM not saying its the pump but if it is they are real cheap...there like 35$ canadian...
    WHATS the update on the cars condidtion????????????????
    and no the timing belt doesnt drive the pump...it drives the oil pump! and of course the valves..
    later
    BEn
    Oct 2001
    thanx Dutchbody !
    MIKE
    89 lxi 95 750 ninja
    Pittsburgh,PA
    It was the lower v-belt. I think it connects a pulley to a/c pump,havn't fixed it yet,but it drives fine for now,have'ta look at repair manual.thanx guys
    kevin
  1. random smoke coming from under the hood
    By twofast4u in forum EFI Tech
    Last Post: 02-16-2009, 05:02 PM
  2. Smoke Under Hood
    By TyphonZ88 in forum 3geez Accords
    Last Post: 04-06-2005, 04:53 PM
  3. white smoke coming from under the hood
    By nwo504 in forum 3geez Accords
    Last Post: 09-05-2003, 03:13 PM
  4. squeek
    By Greg in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-14-2003, 03:51 PM
  5. i just had some smoke come out under my hood
    By shepherd79 in forum Classic Honda Community Chat
    Last Post: 10-15-2002, 08:44 AM
