Results 1 to 4 of 4
Thread: 1 OHM coils
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    1 OHM coils
    how do i run a DVC sub that has 1 ohm coils? can i run two amps to one sub?
    Travis
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    You cannot run a dual coil sub with two amps. The reason for the two coils is to enable you to match the impedence of the sub to your amp. You can either connect them in series or parallel to get the impedence you need.
    LXi User pmip's Avatar
    Oct 2002
    '98 civic ex
    USA
    Yeah, if your amp is 1/2 ohm stable, than wire it in parallel, if it's 2 ohm stable, wire it in a series, or if you have say a 4 channel amp, you could wire each voice coil independantly.
    -Ryan
    Pure White 1988 DX Sedan
    "It takes a big man to cry. And, an even bigger man to laugh at the big man crying"
    NORTH BAY ONTARIO
    who makes .5 ohm stable amps??? i heard about it b4 but i dont know who makes the amp? will a class D work?
    Travis
  1. ignition coils...
    By oscwrestler in forum Performance
    Last Post: 04-13-2008, 07:14 AM
  2. Accel Ignition Coils
    By Tailfin in forum 3geez Accords
    Last Post: 10-03-2006, 04:48 PM
  3. 4th gen coils in 3rd gen??
    By bc86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-28-2004, 06:22 AM
  4. Getting coils for X-mas need info on a ?
    By AccordArizona89 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-19-2003, 11:10 PM
  5. Coils, MSD amplifiers, & wires,,,oh my
    By jteuton in forum 3geez Accords
    Last Post: 07-16-2002, 03:34 PM
