Results 1 to 6 of 6
Thread: No turn signals!
    Oct 2002
    Pompano Beach, Florida
    No turn signals!
    My turn signals stopped working all the sudden...the fuse under the dash is ok, and i pulled an ugly metal relay from the fusebox which the diagram seems to indicate would be the relay...but nothing happens when i select the turn signal lever at all on the dash and the turn signals dont work outside either...i have checked all the bulbs and they seem ok....
    1988 Honda Accord DX Hatchback 5 spd (blown 5th gear) red, new windshield, new master cylinder, minor front end damage popups always up, nice paint on body otherwise, nice interior, axles creaking due to visibly torn cv boots, flipped lid, new turn signal module, rebuilt "performance" motor with 12k miles on it...am/fm cass pullout
    166k miles
    Banned
    Morgantown, West Virginia
    Check the assembly switch on your steering wheel that you turn your signals on with, this more then likely broke. The peices inside are only thin plastic so the parts tend to wear/snap under 13 years of use.
    Nate.
    Oct 2002
    this all seems to be ok...i got the top and bottom pieces off of the steering column, after doing that i used WD40 on it and now i have the following problem:
    Hazard lights wont go out no matter what i do...i had to pull the turn signal relay out just to drive around...
    next step please?
    166k miles
    Oct 2002
    top
    166k miles
    Oct 2002
    It is funny that I just had the exact same problem with my 96 accord 3 weeks ago. It turned out the hazard warning switch was kind of broken and the contacts inside that switch was loose that cut the power to the turn signals.
    You may try hitting the hazard switch a few times and it might work. It worked for me.
    But you can't just remove the switch because if you do then you will have no turn signals. You will have to get a new switch if its broken.
    Added:
    There is only one relay that controls both the turn signals and hazard flash in the 96 accords. It might not be the case in a 3G.
    10/Honda/Ridgeline
    NJ
    the metal relay on ur carb fuse box is not for the flashers, its ur fuel pump cut off relay. U mean the metal relay with holes in its casing? if thts what ur talking about, then its the fuel pump cut off relay
    ur flasher relay and hazard are two different relays as u know. The flaser is kinda in the middle of the fuse box (on the rear that is) and the hazard is kinda to the corner. Replace the relays from the junk or if u want one, i got spares ones lying around and u can have it.
    anywayz, never just spray WD 4d on the steering column switches, they are plastic u dont need to spay that there. If u wanna take and clean the grease, just use a rag or a tissue paper. moisture messed with ur electrical system as u know.
    I have a problem with my car right now where therear works but the front never works with the turn signals or the hazard. I gotta see what is wrong.
  1. Turn Signals
    By Fuzy Navel in forum Interior & Exterior Care
    Last Post: 03-02-2007, 04:20 PM
  2. turn signals???
    By Crazybird in forum Interior & Exterior Care
    Last Post: 09-06-2006, 02:20 PM
  3. Turn Signals
    By Neuspeed007 in forum Interior & Exterior Care
    Last Post: 01-04-2003, 09:14 AM
  4. No turn signals!
    By GhEtTo 88 HB DX 5spd in forum Classic Honda Community Chat
    Last Post: 11-03-2002, 02:16 PM
  5. Turn Signals
    By 89BlackH-Back in forum 3geez Accords
    Last Post: 07-28-2002, 01:20 PM
